Page 1 of 6 1 2 3 ... Last
Results 1 to 10 of 52
Thread: Nissan Mid Engine 7200 Resurrection
    Loyal LaMonte's Avatar
    Oct 2007
    Acton Ca
    Well after a few years and many many different ideas I finally pulled the trigger to redo the back half of my truck.
    Old lay out:
    VG 3.2 Nissan V6 to a Under drive to a torque converter then a Tilton clutch and finally to a Hewland VGC trans axle that had a transfer case attached to the rear.
    It looked super cool and worked ok, but way to exotic for me. If it was cold you would have to heat the engine oil for 20 mins before you could start it. Four shocks per wheel, 2 fox 12 inch air shocks and two 3x10 inch Kusters.
    New lay out:
    VQ40 Nissan V6 mated to a power glide into a quick change rear end with 934cvs
    One 3 inch Revolution Racing per corner
    Last July I pulled her out of a storage container and I gave my boy Spencer Low the Challenge. I wanted to wait till she was almost done to post photos.
Name:	REAR SHOOT.jpg
ID:	115464   Click image for larger version.
ID:	115465   Click image for larger version.
    Oct 2007
    Acton Ca
    Re: Nissan Mid Engine 7200 Resurrection
    Drawings of the new rear arms and upright.
ID:	115467   Click image for larger version.
ID:	115468   Click image for larger version.
Name:	cad upper.jpg
    Forum Junkie racer56's Avatar
    Encino, Ca
    Put a three speed in it.
    Scully Engineering Contractors, Inc.
    Oct 2007
    Acton Ca
    Cant dont it, not enough room.
    Oct 2007
    Acton Ca
    Early mock ups, A turbo 400 would push the CV back to far, (in photo)Power glide is almost is to big.
    Encino, Ca
    A C4 is the same size and weight as a powerglide.
    Oct 2007
    Acton Ca
    I looked at all my options, I even thought to use a 727 mopar transmission do to its small size. The power glide seemed the most bullet proof.
    The C4 and the 727 rob a lot of power.
    Encino, Ca
    The C4 uses the least amount of power of all three speed transmissions. The nissan motor of yours does not have the torque to pull the gear you need for desert racing with a powerglide.
    Oct 2007
    Acton Ca
    I'm not to worried, I'm not gearing it to do 120mph.
    Oct 2007
    Acton Ca
    Here is a photo from last Nov when we started the new rear a-arm and shock mounting design.
Name:	new upper #1.jpg
  1. 7200 engine
    By Sid_Racer in forum Shop - Engine
    Last Post: March 21st, 2010, 23:26
  2. Nissan engine CAD model
    By KitRacer in forum Shop - Engine
    Last Post: January 13th, 2009, 18:23
  3. Nissan KA24E Engine
    By DOG ON in forum Shop - Engine
    Last Post: October 13th, 2008, 22:41
  4. Nissan 7200 Testing
    By RacerX in forum Desert Racing
    Last Post: May 1st, 2007, 15:19
  5. Nissan engine swap question...
    By TumbleBug in forum Shop - Engine
    Last Post: April 8th, 2004, 21:43
