Results 1 to 7 of 7
Thread: Difference between alum and Fiber
    Elite redline's Avatar
    Oct 2001
    Palm Springs
    Anybody now of a non intrusive way to tell the difference between fiberglass and aluminum once its been painted. In need of a method. Thanks in advance
    Mango Racing
    Twitter @Mango_RacingTT
    ADVERTISER mike mcqueen's Avatar
    Jul 2009
    gardena california
    Re: Difference between alum and Fiber
    Feel the thickness. Most aluminum is .090 (bodys) or less. Glass doesnt stay bent, it has a memory. Glass usually has a more gentle curve to the surface. aluminum has more single surface curves, welded corners. Glass has more compound surfaces. English wheel is required for compound curves in aluminum. If the back side is smooth its aluminum.
    Ironman Ramsey_ElWardani's Avatar
    Carlsbad, CA
    Get an Aluminum Magnet from Harbor Freight, the rectangular one is best.
    Ramsey El Wardani
    Smarter Than Dirt!
    One Man Racing
    RDC Addicted DBMETALWORX's Avatar
    Jul 2007
    BUCKEYE AZ
    Thump it, if it sounds like metal, it's aluminum. If it sounds kind of like wood then it's fiberglass.
    SE VENDE: 6ft 16 ga. Pro-former sheet metal brake. Foddrill 4-seat pre-runner chassis. PM for details.. Dave Bost, Dust Bros Motorsports #1050
    Oct 2001
    Palm Springs
    Its a little more difficult. Car is suppose to be all aluminum but once it showed up it was aluminum with fiberglass backing. Now looking more at the car wondering if its not just fiberglass with alum inlays. This is on a street/show car.
    Mango Racing
    Carlsbad, CA
    Ok, maybe you need a serious answer then. Get a multi-meter with very sharp leads and check for continuity where a very small prick won't show - or get an aluminum magnet.
    Ramsey El Wardani
    Smarter Than Dirt!
    One Man Racing
    Senior CraigMT's Avatar
    Feb 2012
    Billings, Montana when I can get home, Middle East when working.
    Is that aluminum magnet 110volt or battery operated?
  1. Alum. body work in Northern Cal?
    By RocketMan in forum Shop - Body and Paint
    Last Post: May 13th, 2009, 09:14
  2. U joint fasteners ...Steel (stock style) or billet alum.?
    By RocketMan in forum Shop - Driveline
    Last Post: August 15th, 2008, 10:51
  3. Alum. firewalls and fiberglass???
    By luckyride in forum Shop - Body and Paint
    Last Post: June 12th, 2007, 07:17
  4. alum AN fittings
    By westtexasbaja in forum Shop - Fabrication
    Last Post: June 4th, 2005, 14:24
  5. Alum floor jack
    By JCA in forum Whatever - General Discussion
    Last Post: November 25th, 2002, 22:41
