Page 3 of 5 First 1 2 3 4 5 Last
Results 21 to 30 of 43
Thread: Shock Oil?
  1. #21
    Fresh Blood RRacing's Avatar
    Jun 2005
    Mesa, AZ
    Re: Shock Oil?
    Quote Originally Posted by philofab View Post
    Bilstein uses F&L Ultra Extreme shock oil.
    Correct. Joel also called it Fox Red, or Fox Oil. Also, thanks Philofab for turning me onto SHDQ. I hadn't been there in a while and was surprised to see all the cool stuff they sold. I bought Lucas shock oil, and the "salesman" told me it was better than the Fox oil. I didn't ask why. Any opinions on their product?
    Loyal 86F-onefifty's Avatar
    May 2005
    El Cajon, CA
    Re: Shock Oil?
    I don't work in the sales dept, but my answer(s) would be:
    Better Base Oil- about 80% of your shock oil is this, so don't cheap out here. *Includes solvent or lack of, which contributes to seal-shrink/swell
    Better Additive Packages- i.e. "up-to-date," because advancements are always being made here, whether the performance/racing aftermarket is watching or not
    Better Viscosity Index Improver- *Important. This is related to what Kris mentioned earlier in the thread. VI testing is done @ 40C/104F and 100C/212F to determine the viscous stability of an oil as it undergoes temp change. "VI improver" is the component added to maintain viscosity at high temps. With lesser quality VI improver, the molecules (think strings) will shear, just like a bolt, at __x__ amount of temp. (not caused temperature alone, but also pressure/wear). After that, the damage is done, and so is high-temp stability. "Better" VI improver can take more heat (and heat cycles) without shearing, which, after cooling, provides a sort of memory to the oil. (The strings can stretch and return to their original form, while the oil gets to keep its stability).
    *However, don't get too caught up on VI ratings, as lab testing is limited to rating the oil's stability up to 100C/212F. Beyond that temp is where better quality VI improver and base oil are truly put to the test. The oil's stability can drop off rapidly, or less than rapidly, depending on the components of the oil.
    That's what makes a "better" oil, IMO.
    Semi-professional racecar driver and amateur tattoo artist
  4. #23
    Powered by Optima philofab's Avatar
    Jun 2006
    JRod's livingroom.
    Re: Shock Oil?
    Quote Originally Posted by RRacing View Post
    Lucas makes a good product. Use the one you like. Kinda like which is better: Chevy, Ford, Dodge, or Toyota?
  5. #24
    Forum Junkie partybarge_pilot's Avatar
    Feb 2002
    Leucadia, CA.
    Re: Shock Oil?
    The Fox red tends to get sticky after a few heat cycles. Not a problem for a race car that gets serviced after every race but pre-runners will have issues.
  6. #25
    Elite F.A.S.T.clothing's Avatar
    Irvine, CA
    I found out you should not mix brands . I had put fox blue oil in my res and tube when I had to top off due to a leak.
    How often should you replace oil and seals. I thought mine would run hot because of weight of vehicle and size of bypass but sway a way took tearing and it was not hot. Then again only did one lap ay barstow and was not at race speeds and the main testing was not constant. Next time I test def going to check again.especially with all the new revalving we did.
    KMR, FK Rod End, Yukon Gear, KMC Wheel, Lucas Oil, PRP Seat, Rigid Ind, MPD Fiberglass, SwayAWay, Primo Powder, Dana Sniff Trans, JuanCo, General Tire, JBA, Fragola, Powermaster
  7. #26
    Jun 2006
    JRod's livingroom.
    Re: Shock Oil?
    On a race vehicle? Every race if your budget allows it. That's considered prep.
    On that same note, some people only rebuild when they leak or once a year.
  8. #27
    Krittro Campbell Kritter's Avatar
    Re: Shock Oil?
    Quote Originally Posted by F.A.S.T.clothing View Post
    How often should you replace oil and seals. .
    If you prep to run up front...every race.
    If its a prerunner...when they leak.
    www.shockseals.com
  9. #28
    Re: Shock Oil?
    Quote Originally Posted by Sparky View Post
    I don't think any of them ran Bilsteins. The discussion is regarding oil for Bilstein, not Kings. We run Bilstein and I know what temps they run. Just because ^^^their shocks got that hot does not mean that *all* shocks get that hot.
    Temp indicators and with a gun.
    An infrared gun is not accurate on nickel plating. Temp indicators do workthough.
    I was offering general knowledge on oil and following up an example to rebute your information.
    The consensus Gadzooks was your shocks dont get hot becuase you guys dont drive all that fast. Not my words. I dont know you nor have I seen you race.
    My personal take on oil is I would never buy it from the shock manufacturer. They are just a middle man marking it up. Buy it based on properties and price range and change it as often as you can afford.
    www.shockseals.com
  10. #29
    Elite Sparky's Avatar
    Apr 2006
    Feeniks, Aridzona
    Re: Shock Oil?
    Quote Originally Posted by Kritter View Post
    That is classic. I may need to steal that for my sig line.
    Gadzooks Racing - JeepSpeed 1717 - 4 Wheel Parts, Rubicon Express, Bilstein, Rigid Industries LED Lighting.
  11. #30
    Elite Pee Wee's Avatar
    Chino Hills Ca.
    Re: Shock Oil?
    I didn't say it, but I do think it's funny.
  1. Replies: 3
    Last Post: April 23rd, 2011, 10:55
  2. vw bug shock
    By kx125str99 in forum Shop - Suspension & Steering
    Last Post: December 6th, 2010, 12:03
  3. shock rebuilders in San diego/shock question
    By F1shifty in forum Shop - Suspension & Steering
    Last Post: May 30th, 2009, 23:57
  4. Top of Shock Aft of Bottom of Shock
    By Supertoys-Adventures in forum Shop - Suspension & Steering
    Last Post: February 27th, 2009, 18:47
  5. Coilover shock for a helper shock?
    By mudhound72 in forum Shop - Suspension & Steering
    Last Post: January 9th, 2008, 20:57
