Results 1 to 10 of 18
Thread: 4130 post heat treating welding
    Prospect bajamatt's Avatar
    Salt Lake City, Utah
    In the process of making some new uprights. They are made from 4130 plate. We are planning on having them heated treated, but I was told that once they are heated treated you can no longer weld to them. Thoughts? I'm new to this whole heating treating process. I've read a lot of the other threads, but most of them deal with pre-heat treat processes. Thanks in advance!
    Senior gawdodirt's Avatar
    May 2003
    Gilbert, AZ
    Re: 4130 post heat treating welding
    You can have them annealed AFTER heat treating to weld additional pieces to them. Consult a metallurgy engineering specialist.
    "I'm the "FUN" in Dysfunctional!"
    Silverdale, WA
    You can weld on them after they are heat treated. . .the only problem is that you will change the heat treat in the HAZ, so it is best to weld them up prior to heat-treating otherwise you're gonna be heat treating them twice or defeating the whole point of heat treating in the first place.
    May 2003
    Gilbert, AZ
    Depending on the degree of treatment; how hard. It can also crack or fracture in the area if you weld a heat treated part. The Most likely scenario is a crack you can't see. Most effective would be to just stress relieve the parts, or cryogenically treated.
    GD
    Forum Junkie CRAIG_HALL's Avatar
    Oct 2002
    Hesperia/Ontario
    Weld them up, stress relieve & heat treat. Now it will have uniform strength throughout. If a repair is needed, just weld it up then stress relieve & ht again. If you don't, you will have created a weaker spot where the weld area is. Not a huge issue as many people don't HT in the first place.
    A computer makes as many mistakes in two seconds as 20 men working will in 20 years
    Thanks for all the input. We are planning on welding everything up before heat treating. I was just thinking long term if we ever had to weld on them in the future (crack repair, steering changes, etc). But it sound like it's not too big of a deal.
    Now for a stupid question - what is the process for stress-relieving? Do they usually do this as a process of the heat treating?
    Thanks again
    May 2003
    Gilbert, AZ
    Quote Originally Posted by CRAIG_HALL View Post
    I was told by a heat treatment company that it has to be annealed before re-welding.
    Stress relieving can be heat or vibratory.
    GD
    Elite Dirtracer 619's Avatar
    El Cajon
    can some one explain in plain english what I think (and could be wrong) is weld it run a torch oover it then what beat on it with a hammer or somthing??
    talking about 2" 120 wall cromo
    Thanks Clint and FiberwerX
    link to our build http://www.dezertrangers.com/vb/dr-rides/108105.htm
    Silverdale, WA
    Not sure what you mean there. . .are you suggesting welding and then mechanically stress relieving the part with a hammer with regards to a structural part?
    . . .or are you talking about when sheetmetal guys will anneal and hammer a weld for bodywork type of work?
    El Cajon
    Just don't exactly know the best way to weld.cromo tubing. Need step one two three
    What is meant by releiving
  1. plating/heat treating a frame
    By Andrew in forum Shop - Fabrication
    Last Post: July 10th, 2011, 17:03
  2. Heat Treating a Chromoly Frame
    By rfuge in forum Shop - Fabrication
    Last Post: April 9th, 2011, 11:08
  3. Heat treating welds?
    By mexracer10 in forum Shop - Fabrication
    Last Post: November 16th, 2008, 23:02
  4. heat treating
    By D.Mavis in forum Shop - Fabrication
    Last Post: August 15th, 2008, 16:43
  5. heat treating
    By dezerts10 in forum Shop - Fabrication
    Last Post: December 18th, 2007, 17:46
