Results 1 to 5 of 5
Thread: oil cooler pluming
    Fresh Blood 650Rider's Avatar
    Mar 2007
    Manhattan Beach, Ca
    oil cooler pluming
    I was wondering what is the proper size tubing to use when pluming my prerunner. I have to run the trans lines and engine oil lines and not too sure on what the best size would be. It's a full size chevy with a 6.0 ls engine(450 hp) and a 4l80e trans. The trans has 2 large cbr oil coolers with fans that the lines will be going to which I belive are -10 fittings, and the engine will have a frame mount cooler, any advice will help. Thanks!
    Mar 2007
    Manhattan Beach, Ca
    Re: oil cooler pluming
    Wow, no one, really?
    Senior esbyota's Avatar
    Jun 2004
    Phoenix, az
    -8 for both.
    Brad 159
    Nocturnal Industries, You local Phoenix fabricator.
    Elite redline's Avatar
    Oct 2001
    Palm Springs
    -8 for trans lines and -10 for the oil lines. Make sure you plumb into the bottom of the coolers and out the top.
    Mango Racing
    Twitter @Mango_RacingTT
    Elite loufish's Avatar
    May 2005
    Burbank, CA
    You want the lines to be bigger then the original fittings out of the trans and engine to make sure you have little to no pressure drop.
    For example the -8 lines for the trans are bigger then the common 5/16" and sometimes 3/8" steel factory lines.
  1. oil cooler
    By ryno_racing in forum Class 9
    Last Post: May 19th, 2010, 16:11
  2. Oil cooler on a 091
    By just josh in forum Shop - Driveline
    Last Post: August 31st, 2009, 15:03
  3. Class 8 - Oil Cooler? Or No Oil Cooler
    By Iggle in forum Shop - Engine
    Last Post: May 24th, 2007, 12:37
