Page 2 of 7 First 1 2 3 4 ... Last
Results 11 to 20 of 67
Thread: Holley carb issues
    Loyal pkonopasky's Avatar
    Jun 2011
    Trabuco Canyon, California
    Re: Holley carb issues
    Quote Originally Posted by orbot View Post
    2 diferent carbs and same issues..... is the timing ok?? what distributor are you using? are the spark plug wires good?
    I am using the MSD offroad ignition system, brand new wires and plugs, and we have the timing around 20 advanced
    Jun 2011
    Quote Originally Posted by partybarge_pilot View Post
    OK, which accel pump cams are you using and if you have 2 UMP's, whats the plemun on top of the carb look like?
    The carbs are straight out of the box, nothing changed.
    Forum Junkie Zambo's Avatar
    Get rid of that little intake hat and put a real air cleaner on it! We had the same problem with our stock full, that little hat just doesn't hold enough air for immediate demand when you need it.
    Also, how much vacuum is your motor making? A 383 with a big cam might not make much vacuum, and you're running vacuum secondaries. I'm not that smart with carbs but I think most desert racers would run mechanical secondaries, I know I do.
    Just walk away. I will give you safe passage in the Wasteland. Just walk away and there will be an end to the horror. I await your answer.----The Lord Humongous
    Forum Junkie partybarge_pilot's Avatar
    Feb 2002
    Leucadia, CA.
    Quote Originally Posted by Zambo View Post
    X2, those with the offset inlet create a swirl over the top of the carb that screws with the highspeed air bleeds. Get the larger one with dual inlets. Dynoing a 430SBF with one of those versus a 14" air cleaner lost us 75HP. The larger dual inlet plenum was about the same as the 14"...........
    Feb 2002
    Leucadia, CA.
    Also, I think those come with the red cam. Run the brown or yellow.
    http://www.holley.com/data/Products/...mpCamGraph.pdf
    Edit, if you put on the DP, run the pink cams...........
    Dec 2009
    Desert Rat
    Check the screen IN your fuel pump.... take off the bottom plate
    Jun 2011
    Before messing with the air cleaner I'm going to check the fuel pressure next weekend and check that off the list. It does open up the secondaries well though! I'm going to have to figure out a different way to do the intake it that's the problem though
    Jun 2011
    Where do you suggest to get a dual inlet plenum? Would that be a good route to switch to?
    Jun 2011
    Quote Originally Posted by 12LaPaz View Post
    I'll pull it apart before I take it out next! Thanks!
    Feb 2002
    Leucadia, CA.
    Quote Originally Posted by pkonopasky View Post
    The UMP one is bigger, could be bigger still.....
  1. 22R Holley Carb Setup
    By Baja_XJ in forum Shop - Engine
    Last Post: February 8th, 2011, 15:40
  2. Carb issues????
    By Motoren in forum Class 9
    Last Post: March 18th, 2009, 09:46
  3. Dual Carb or Single Carb on Type 4?
    By Wendell #527 in forum Shop - Engine
    Last Post: September 16th, 2008, 04:36
  4. Any Holley carb builders/tweekers here?
    By scottm in forum Shop - Engine
    Last Post: May 6th, 2008, 18:11
  5. possible carb issues
    By Big_Rich in forum Shop - Miscellaneous
    Last Post: August 23rd, 2003, 12:37
