Results 1 to 7 of 7
Thread: Leaking fuel filter connections?
    Silverdale, WA
    I was under the truck the other day and I saw that my fuel filter connections were leaking. . .you shouldn't need teflon tape on AN fittings right, only on NPT fittings correct?
    I'm not sure which fittings were leaking the NPT fittings on the NPT-to-AN adapter or the AN fittings, but I just wanted to make sure that I wasn't mistaken when I fix this over the weekend.
    Here's the filter I'm using
    it has 3/8" NPT inlet and outlet fittings. . .
    I'm using thes 3/8" NPT to -6 AN adapter fittings
    and these -6 AN fittings I for the fuel line
    Thanks for the help!
    Elite Sparky's Avatar
    Apr 2006
    Feeniks, Aridzona
    Re: Leaking fuel filter connections?
    Right or wrong, I have always uses some teflon paste (not tape!) on the NPT stuff. No sealer ever on the AN fittings. I have had bad swivel fittings that have leaked so it might be the fitting itself.
    Gadzooks Racing - JeepSpeed 1717 - 4 Wheel Parts, Rubicon Express, Bilstein, Rigid Industries LED Lighting.
    Silverdale, WA
    Any good way to check the fitting itself?
    Wham Spore movindirt's Avatar
    Apr 2005
    24.5mi from Timbuctoo, Ca
    Have you tried just tightening the fittings? Teflon tape can work with AN fittings but it is not the correct way. The only way to check that I can think of would be to take filter out, only removing from AN fittings. Then cap output side and make small line to allow you to pressurize it and check under water. DON't get CrAZy with the psi!!!! Don't need to hurt yourself. Good luck!
    Silverdale, WA
    Good idea. . .Thanks MovinDirt
    Forum Junkie racer56's Avatar
    Encino, Ca
    AN fittings that have been over tightened will start to leak eventually, replace with new ones. Using push-on style hose and fittings on the pressure side of a fuel system is dangerous in my opinion and asking for a fire.
    Scully Engineering Contractors, Inc.
    Silverdale, WA
    It's a mechanical fuel pump so those fittings aren't on the pressure side, but good point. . .
    . . .the fittings have only been tightened once and after looking more closely at them I think that I didn't tighten the NPT fittings enough. It looks like the fuel was leaking between the fuel filter itself and the 3/8" NPT-to-AN6 adapter fitting.
  1. Pre-Pump Fuel Filter- 100 micron or 40 micron???
    By desertspeed in forum Shop - Engine
    Last Post: October 1st, 2012, 00:01
  2. Fuel pump? Fuel filter?
    By Ford-Fanatic in forum Shop - Engine
    Last Post: December 3rd, 2011, 13:01
  3. Radio connections
    By cosmo in forum Shop - Electrical
    Last Post: December 28th, 2009, 17:23
  4. Fuel Filter Replacement?
    By Sean in forum Shop - Miscellaneous
    Last Post: September 29th, 2004, 06:23
  5. Fuel Filter?
    Last Post: August 22nd, 2004, 10:25
