Results 1 to 4 of 4
Thread: power steering filter?
    Jun 2006
    el cajon, ca
    Is it ok to run an in line filter for the power steering? Kind of like the inline fuel filters or do you have to run the ones that are attached to the bottom of the reservoir?
    If you can run an inline filter, can you run it on the line from the p.s. pump to the servo so it will catch any debris from a broken pump (or is the psi to high)?
    thanks for any help!
    Senior Robin Hood's Avatar
    Feb 2007
    Tucson, AZ
    Re: power steering filter?
    Quote Originally Posted by kcb2525 View Post
    In line filter is the way to go. Should be between the steering box and the resivor.
    Senior baja stu's Avatar
    Sep 2005
    Menifee, CA
    Your filter should be before the pump / after the rez.
    Cross-threading is just as tight as Loctite
    Silverdale, WA
    Quote Originally Posted by baja stu View Post
    Unless you have an integral reservoir. . .then between the box and the pump in the return line.
  1. Electric power steering steering
    By 1wayne in forum Shop - Electrical
    Last Post: November 19th, 2012, 08:29
  2. 5-1600 car power steering or no power steering!!!
    By CHukkawala in forum Desert Racing
    Last Post: May 1st, 2009, 14:50
  3. power steering
    By ZROVER in forum Shop - Suspension & Steering
    Last Post: September 27th, 2008, 07:54
  4. PSD power steering goes out %$#@!
    By Waldo in forum Shop - Suspension & Steering
    Last Post: September 2nd, 2008, 10:44
  5. Power Steering Set-Ups
    By rokker in forum Shop - Miscellaneous
    Last Post: March 27th, 2004, 20:37
