Page 3 of 4 First 1 2 3 4 Last
Results 21 to 30 of 40
Thread: What is the most powerful front wheel drive engine from the factory?
  1. #21
    Accepted j10-401's Avatar
    Dec 2007
    Fallbrook, ca.
    Re: What is the most powerful front wheel drive engine from the factory?
    Volvo v8. i believe its right around a 4.0L, engineered and built by Yamaha 315 HP @5850 rpm 324 LB FT @ 3900 rpm 10.4:1 compression ratio bad ars little engine all aluminum.
    When in fear stab it & steer!!!
    Elite Scott_F's Avatar
    Dec 2003
    Anaheim
    Quote Originally Posted by Short Bus View Post
    Ford's 3.7l V6 has 305hp and is used in some Ford Edge and some Lincolns. The 3.7l is also now available in the police version of the Explorer (the civvy Explorer gets a 3.5l only). The 3.5l version makes about 285hp and is more common. Techincally, the Ecoboost 3.5 is an awd application. It isn't available in FWD-only, but it is mounted the same as the FWD non-EB V6s.
    So it is mounted transverse or longitudinal? I like the Nissan VQ series.
    Quote Originally Posted by j10-401 View Post
    Never heard of this one. More details please. Years, model, etc.
  4. #23
    Elite Short Bus's Avatar
    Feb 2010
    phlattland
    Quote Originally Posted by Scott_F View Post
    The SHO ecoboost is a transverse mount. It has some kind of PTO to send power to the rear wheels when needed.
  5. #24
    Dec 2003
    Anaheim
    Didn't the Taurus SHO have a Yamaha V8? Is it the same engine?
  6. #25
    Dec 2007
    Fallbrook, ca.
    It's not the same engine as the sho, built exclusivly for Volvo came in the xc90 suv. 2005-2008 and the 2007-2008 s80 sedan. Compact little package DOHC. Has potential in an offroad car.
  7. #26
    Dec 2003
    Anaheim
    I imagine there is no aftermarket support for that engine. Does it use a Volvo auto transaxle? What would be the best choice for ECU? Megasquirt?
  8. #27
    Dec 2007
    Fallbrook, ca.
    Yes uses a volvo transaxle (Aisin Warner) the problem I see is the ECM controls the engine and trans through CAN comunication to a TCM mounted on top of the trans. Aftermarket support is probably close to none. If you could find someone to build a stand alone ECU for the engine and bolt it to a trans that is not dependent on electronic control it would be a pretty cool set up. The volvo trans axles are junk anyway.
  9. #28
    Prospect
    Nov 2011
    Australia
    Mitsubishi lancer Evo. east west all wheel drive, lock the center diff and remove the rear drive.
    tons of aftermarket support - even dog gearsets for the gearbox. Small highly strung engine but if you have a driver that can keep it on the boil it's also very light.
    However they have a terrible turning circle due to the strength of front CVs required.
  10. #29
    Formerly "Cracka Racing"
    Apr 2005
    Huntington Beach, California
    Isn't it also used in some super car? It seems like Jeremy was making fun of one of the other guys on Top Gear for bringing something powered by an XC90 motor to a competition and the defense was that it was made by Yamaha.
    Found it:
    The Noble M600 is powered by the same engine.
    http://en.wikipedia.org/wiki/Noble_M600
  11. #30
    Prospect
    Dec 2010
    gawler, south australia
    Quote Originally Posted by NoThrottle View Post
    I was thinking of using something like this, lots of support for the engine and massive amounts of power available.
    Youd be surprised what euro tuners use and do, not just the main stream American/Australian cars like the GOLF but the Merc G wagon and some of the lower level saloons.
  1. Steering setup suggestions front wheel drive
    By Kenshiro in forum Shop - Suspension & Steering
    Last Post: April 28th, 2012, 08:21
  2. Front engine plate/ accs. drive mounts
    By LINKMS15 in forum Shop - Engine
    Last Post: June 23rd, 2011, 09:52
  3. Front engine Vs. Rear engine
    By punchdrunk monkey in forum Desert Racing
    Last Post: February 20th, 2007, 12:42
  4. Front rotors need 5/8" wheel studs ....
    By motoxscott in forum Shop - Miscellaneous
    Last Post: April 27th, 2004, 11:22
