June 30th, 2012, 10:05
#1
Electrical problems
Hello wuys this is my fist post so take it easy on my, I have a Titan With a horrible wiring job looking for someone to rewire it. To the point to cancel all that electrical crap that don't let us drive our trucks the way we want. Any help appreciated thanks.
June 30th, 2012 10:05
# ADS
Join our community today |
Re: Electrical problems
Very vague question......What is it that you need?....Is there a problem or do you want to by-pass the internal controls in the ECU?......
I want to rewire the truck, to flush the ecu to make the efi work with the least amount of censors, but keep the a/c power windows, and all that electrical goddies.
July 11th, 2012, 20:40
#4
Just so you know, the Titan needs just about all those sensor inputs to work correctly.....The trans, engine and ABS modules all talk to each other. We're not just talking about a few lights on the dash if you get it wrong.
I have done "race" harness's where you go thru the entire wiring harness and strip out everything you don't need, but you do need to know what to keep and what to chuck...and of course the entire harness is sitting on the shop floor.
Do you need electrical schematics?.....I have quite a few of them for the Titan...
July 11th, 2012, 22:04
#5
If you are trying to keep your stock ecu and trans you are looking at not just rewiring but reengineering of major components in the truck. I have a titan and have replaced every part of the truck and have also replaced nearly all of the stock harness. But I have a stand alone ECU and a manual shift trans and no abs, all that stuff is what will cause you to pull your hair out. Since I don't know what your goal is it's hard to give any advise just share what my experience is. If you need help with a stand alone ECU I would recommend Chris at Danzio.
July 12th, 2012, 20:07
#6
I would think big time!
July 13th, 2012, 19:18
#7
so what do you recomend, can you cancel the abs, the o2 censors, and rewire the truck?
July 13th, 2012, 19:19
#8
can you give me the number for chris?, how much have you invest in your titan?
July 13th, 2012, 20:56
#9
you can't get rid of the stock ecu unless you also change the transmission. The two are linked. I have a GM 4L80 with manual shift a 9" rearend and all new hubs and brakes with no abs. What have you modified that is causing your truck not to run the way you want it to?
July 18th, 2012, 20:52
#10
Originally Posted by
MasterWerx
I really don't know I bought the truck like that
, I believe the previous owner pull the engine out, and when he try to put it back on the miss plug a sensors and wirrers I mean the wiring is a mess
