Results 1 to 10 of 16
Thread: IPOD Control with no head unit- Kenwood KOS-A300 $50
    Senior desertspeed's Avatar
    Oct 2002
    San Marcos, CA
    I have been looking for a better way to control my IPOD while driving. It is hooked directly up to my PCI intercomm, and I keep the IPOD in a case in my center console to keep it out of harms way. I was originally using the RacerX setup, but I was getting a lot of alternator whine and after playing around with it I realized that I really don't need the extra amp that it comes with. So, right now I just have the IPOD connected directly to the intercomm using this cable, http://www.sonicelectronix.com/item_...y-Adapter.html, and this volume knob http://www.amazon.com/PAC-Remote-Amp.../dp/B0002J226O to control the volume. This works well and keeps the IPOD charged, but I end up just putting it on random- if I want to change songs or anything I have to dig the IPOD out, which is pretty much impossible while driving.
    So, I have been searching online for something that I can mount on my dash and will allow me to control the IPOD remotely, and I ran across this: http://www.crutchfield.com/p_113KOSA...em.html?tp=120. It was originally $250 but they are discontinued, so Crutchfield is selling them for $50 with free shipping. Not only does it have a remote control knob that will control the IPOD, it has a remote display face that can be surface or panel mounted as well, and it will charge the IPOD through the IPOD cable. It can also be used with any other USB storage device, HD Radio, Satallite radio, Bluetooth, etc.
    I just thought that I would share......
    Cuama up, cracka
    Fresh Blood lbcprerunner19's Avatar
    Oct 2009
    Scottsdale, AZ
    Re: IPOD Control with no head unit- Kenwood KOS-A300 $50
    nice find!
    Loyal DezerBlingMoto's Avatar
    Feb 2011
    AZ
    could u elaborate a little on this , so what does it connect to and how does the music get from this thru youre intercom to youre helmet?
    RDC Addicted frankh's Avatar
    ventura,ca
    Oct 2002
    San Marcos, CA
    Quote Originally Posted by frankh View Post
    That would have probably worked too, although I would have still needed to mount the remote somewhere.
    The problem with every other remote I have found is they plug into the ipod's bottom connector, so you cant plug the ipod into anything else. I need to have mine plugged in to charge, etc.
    Cuama up, cracka
    Oct 2002
    San Marcos, CA
    Quote Originally Posted by DezerBlingMoto View Post
    Right now I am just using this cable, http://www.sonicelectronix.com/item_...abilities.html, and this volume knob http://www.amazon.com/PAC-Remote-Amp.../dp/B0002J226O to control the volume. The first cable both charges the ipod and adapts it to an RCA plug, which connects to the volume knob. From the volume knob it connects to my PCI intercomm- PCI has an adapter with RCA plugs on one side and the other end plugs into the intercomm. From there just the standard headset cables to my headsets (or a helmet).
    Here is the PCI adapter: http://www.pciraceradios.com/Product...01304688313089
    Cuama up, cracka
    Forum Junkie Zambo's Avatar
    Quote Originally Posted by desertspeed View Post
    Don't most remotes charge the ipod too?
    Just walk away. I will give you safe passage in the Wasteland. Just walk away and there will be an end to the horror. I await your answer.----The Lord Humongous
    Junior prerunner404's Avatar
    Nov 2009
    lake havasu az
    Pretty sure you need a head unit for this set up if its the same one i have in my razor i needed to add a head unit for it all to work right.
    Forum Junkie racer56's Avatar
    Encino, Ca
    Scully Engineering Contractors, Inc.
    Fresh Blood orbot's Avatar
    Jan 2008
    Chula Vista, Ca
    Quote Originally Posted by prerunner404 View Post
    It works for him cause he is using his intercom.
    might be good if you could find a way to send the signal to an amp or two
  1. Kenwood TK-790H
    By esbyota in forum Shop - Electrical
    Last Post: April 10th, 2012, 09:05
  2. DVD Movies to iPod
    By steveG in forum Whatever - General Discussion
    Last Post: May 3rd, 2011, 22:16
  3. Mp3 Or Ipod While Racing?
    By KODIAK7 in forum Desert Racing
    Last Post: April 16th, 2008, 08:13
  4. IPOD's In Racecars?
    By Andy McMillin in forum Shop - Electrical
    Last Post: January 22nd, 2007, 22:14
  5. PCI Kenwood radio
    By KELLENC in forum Shop - Electrical
    Last Post: August 16th, 2006, 12:18
