OK, so I know it's not uncommon for a VW to leak, in fact I think that it's a given fact that they do....so here's my situation.....
Finishing a bug for a customer....put a 1600 DP motor in that he supplied....come to find out that it's a "refurbished" motor and not a rebuilt......perfect....
Fired the engine, tuned it...runs great. Sitting in my shop, no leaks.....drive it 100 yards...dumps oil like there isn't a gasket on it....
Basically I took the motor down to the long block...I pulled the fuel pump off, replaced both gaskets and the stand-off...removed the carb, intake & tubes, dog-house and the generator, replaced both gaskets and the baffle under the generator stand, put another new o-ring on the new 009 dist., re-sealed the sending unit with teflon tape, pulled the oil pump and resealed the oil pump body and the cover.....I used "gasgacinch" on all my gaskets (like I always do)....still Freakin' leaks....
It only leaks under load...I cannot see an active leak while it's sitting in my shop....oil seems to still be coming out near the oil pump somewhere....maybe from the case split from the crank to the oil pump body? I checked the case bolts...all are tight....
The big problem is the car is supposed to leave my shop tomorrow and it's 8:15 at night.....thought I had the leak fixed until I did one last test....
ANY help would be appreciated...thanks in advance....
Paul
... do you have another oil pump to bolt on, are the surfaces flat on the pump case and block ? ... oil pump gasket failure ?
Bookmarks
