+ Reply to Thread
Page 1 of 4 1 2 3 ... Last
Results 1 to 10 of 34
Thread: Electric water pumps
    Spam Whore Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot has a brilliant future Dezertpilot's Avatar
    Jul 2005
    Newport Beach, CA
    Rep Level
    1859
    Rep Power
    34
    I was looking through my Summit mag and saw a universal electric water pump. It has a bracket that sits off the side of your motor and has a small motor and from the motor and then a belt to your water pump. It says that it frees up to 17 HP and I was kind of thinking about putting one of these on my 4runner. I have a 1987 7m-ge motor that is swapped in. I know I would call and ask Summit if it would fit my app but lets say it does. Is it worth it? Its under $180 and looks nice. I do know its one more electrical accessory but if I can gain 10 HP or more I think I would be happy. What are you guys thoughts on this?
    Nikita Khrushchev said"We can't expect the American People to jump from Capitalism to Communism, but we can assist their elected leaders in giving them small doses of Socialism, until they awaken one day to find that they have Communism. "
  2. Supporter of the Site
    Forum Junkie steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG's Avatar
    Jul 2003
    Arroyo Grande, CA
    Rep Level
    710
    Rep Power
    19
    Re: Electric water pumps
    I don't think its worth it. It's just one more thing to go wrong in the desert. Especially when the cooling system is concerned, simple and effective is the key. Besides that, most of the electric water pump drive kits are designed for short duration use like drag racing.
    I know a little German... he's sitting over there.
    GoFastBroncos.com
    Elite TheWebWheeler will become famous soon enough TheWebWheeler's Avatar
    Jul 2005
    Burbank , Calif
    Rep Level
    18
    Rep Power
    Yeah do really want to have that be what bones you in the middle of no where?
    I agree If your only drag racing or maybe running in a short corse at a track like ROR then it might be worth persuing But if your running out in the middle of nowhere I would'nt do it..
    Elite Josh_K will become famous soon enough
    Apr 2003
    Colton, CA
    Rep Level
    27
    Rep Power
    10
    I dont think those things will build enough block pressure to cool a car that is ran continuisly. I think there nitch is in 1/4 mile cars.
    It is typical for a v8 race engine to run 30 to 40 psi in the block of pressure. This reduces the ability of the coolant to boil. This is how cars can run temps or 265 and not boils the coolant off.
    BTW, I am sure you know this but when you take the thermastat out and run a disk in it place, the smaller the hole in the disk and cooler the engine will run. The reasons are two fold. 1 more block pressure. 2 the coolent crosses the rad slower and has a more time to exchange the heat to the air making cooler water.
    Josh
    Ironman Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani's Avatar
    Carlsbad, CA
    Rep Level
    8840
    Rep Power
    107
    Josh, if that were the case, why wouldn't it blow all the coolant out of a 18 -22lb radiator cap, being that it is a closed system and pressures equalize in the whole system?
    Ramsey El Wardani
    Smarter Than Dirt!
    One Man Racing
    Accepted Stephen will become famous soon enough
    Dec 2003
    Carbondale, CO
    Rep Level
    21
    Rep Power
    9
    I almost hate get this started but I guess I have to.
    Slowing the water down through the radiator will only hurt your heat rejection through that radiator. The higher the flow rate, the higher the heat rejection rate. Reason is that heat is transferred best at high temperature differences. If your water comes out at 260 and the air is 100, you have a 160 degree difference and heat will fly out of the water since the air is so much cooler. If your water is only 200, you reject less heat because there is a lower temp difference.
    If you slow the flow rate down in the radiator, the water at the inlet will be our theoretical 260 and the water at the outlet may only be 200. The water at the outlet of the radiator will be rejecting heat slower because it's so cool.
    If you speed up the flow rate, the water at the inlet will still be 260 but the water at the outlet could be 240. The higher outlet temp will reject more heat to the air before it heads back to the motor for another load of heat.
    Don't get hung up in trying to control temperatures with this example or even in real life, you're really trying to reject HEAT. If you get rid of lots of heat, temps will take care of themselves. I know it seems intuitively obvious that you would be better off putting that slower moving 200 degree water in the motor but it's not.
    This same idea is why running high coolant temps is good for cooling. If have 100 degree air and try to regulate the block to 160 degrees, you have to have a huge cooling system because you only have a 60 degree temp difference to reject heat with. If you run a 260 block temp with the same air, you reject the same amount of heat with a smaller radiator.
    Owner of one slow K5.
    RDC Addicted Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson has much to be proud of Chris_Wilson's Avatar
    San Diego
    Rep Level
    914
    Rep Power
    22
    "being that it is a closed system and pressures equalize in the whole system?"
    Sounds like you are thinking of a static system, not a dynamic system.
    When fluids are flowing, a restriction to flow will result in a pressure
    differential across the restriction.
    An analogy would be a voltage drop due to current flowing through a resistor
    (or a wire which has some resistance). When the current stops flowing then the
    voltage becomes the same on both sides of the resistor.
    Likewise, there are restrictions to the flow of coolant in your system. Some are
    insignificant, others not. The pressure before and after the water pump is not
    equal (except when the pump stops pumping!)
    Or I could be wrong...
    Jul 2005
    Newport Beach, CA
    Rep Level
    1859
    Rep Power
    34
    Ya Im not going to do it but this kinda brings up an interesting topic.
    Apr 2003
    Colton, CA
    Rep Level
    27
    Rep Power
    10
    Stephen..... I don’t even know what you said? I couldnt get past you second of third sentence.
    Ramsey, wait a moment and I will get to you.
    Chris, I think we are on the same page.
    O.K. I will type slowly for the thinking impaired. Please don’t read too fast.
    First one given, the higher the pressure on a liquid the high the temp will need to be to make the fluid boil. Example, water at an elevation higher than sea level boils at less temp than water at sea level. Furthermore, we have all heard that if an astronaut’s space suite pops a leak that his blood will boil. Well that happens because the pressure drops so low that it gets to the point that the blood in his body will boil at 98.6 f thus killing him/her just as water boils at a lower temp in the mountains than at the beach. So, as water or blood boils at a low temp/low pressure water (and blood) will boil at a higher temp and pressure that we are accustom too when the pressure is raise above that of atmospheric pressure.
    Now back at it.
    In a running engine Pascals law doesn’t apply because the restrictor plate adds a resistance to the system and builds a pressure on the fore side of it which happens to be in the block. As I have said a block can run a pressure of 40 psi but there will be less that 24 psi in the rad because it is on the aft side of the restriction.
    For instance, if your 8 truck is really hot 250+, and you keep the rpm’s up (3,500+) the water wont boil out of it because all the pressure that is in the block fore side of the restrictor plate is raising the boiling point of the water in the block to a point higher that the temp of the coolant. Now it you shut the engine off and Pascals law become effective and the water will pop the cap on the radiator.
    Now I am sure some one will argue with me and thats fine, just be aware that I know this works because I have experienced all this stuff for my self so you’re not going to change my mind!
    Josh
    Apr 2003
    Colton, CA
    Rep Level
    27
    Rep Power
    10
    Now Stephan, I have tried to read your post again and I still don’t get your point. Now please explain how my 909 logic is wrong.
    If a coolant flow slowly across a radiator than it has more time to transfer it heat into the surrounding (ambient) air.
    BTW, what ever you come back with will most likely be wrong because I know smaller holes in restrictor disks = cooler water temps. It’s as simple as that.
    Now you are right about the closens of the temp spread being less efficaint but we not taking about normal temps here. I am talking about temp that will cause the water to boil in a block and warp heads.
    Josh
    Oh one more thing, please don’t come back with, “if smaller is better than block the flow off”.
+ Reply to Thread
  1. Electric water pump
    By HardCharger81 in forum Shop - Engine
    Last Post: May 22nd, 2010, 15:58
  2. what fuel pumps are these?
    By NicksTrix in forum Shop - Engine
    Last Post: October 1st, 2008, 22:54
  3. In Line Electric Water Pumps????
    By Iggle in forum Shop - Engine
    Last Post: August 15th, 2008, 12:56
  4. electric water pumps
    By circleb in forum Shop - Engine
    Last Post: March 11th, 2008, 16:03
  5. electric fuel pumps in corr
    By GBoyer in forum Shortcourse Racing
    Last Post: September 11th, 2006, 19:39
Bookmarks
