+ Reply to Thread
Page 1 of 5 1 2 3 ... Last
Results 1 to 10 of 44
Thread: Class 10 Motor Combinations
    Fandroid FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo has a reputation beyond repute FlyHiFlyLo's Avatar
    Dec 2003
    North Mexico
    Rep Level
    13000
    Rep Power
    157
    Cool Class 10 Motor Combinations
    What do you think is the best engine combo to run in a class 10, 2 seater.
    What make engine, what mods, Service life, and how much horsepower are they making.
    ENGINE LOCATION & DISPLACEMENT
    Any engine may be used providing:
    A. It is a design that has been series produced in quantities of 5000 units or
    More and is readily available to the general public in the U.S.A.
    B. It did not displace more than 2000 cc in the stock form.
    C. It retains a maximum of four valves per cylinder.
    D. It does not displace more than the following:
    E Air-cooled engines may use dual carburetors. or stock fuel injection
    Water-cooled engines
    Two-seat 1800cc – 8 valve Single two-barrel carburetor
    Two-seat 1750cc – 16 valve Single two-barrel carburetor or stock fuel injection with max throttle body of 58.5cm
    Air-cooled engines
    Two-seat 2000cc – four cylinder push rod
    F) Single and two-seat vehicles may use one carburetor providing:
    1. It retains a maximum of two ventures per carburetor.
    2. Maximum allowable venturi size is 42mm.
    3. Carburetor(s) must be of the production automotive type.
    G) Fuel injection is stock production with the following restrictions:
    1. Intake manifold will remain as delivered by the manufacturer. It must retain it’s stock shape, size, and configuration. No porting or other modifications. Ports may be matched to the heads, but matching may not exceed .250” (1/4 inch) deep. Manifold must be the unit that was installed and delivered on the engine by the original manufacturer. Only U.S.A. delivery fuel injection is permitted. Manifold must be installed and sold on production vehicles for street use in the U.S.A. and be readily available to the general public.
    2. Throttle body must be production (OEM) type readily available to the general public in the U.S.A..
    Quote Originally Posted by Mark_Miller View Post
    what a dick
    Quote Originally Posted by TT#54 View Post
    Dicks.
  2. Supporter of the Site
    Senior Aflac is a glorious beacon of light Aflac is a glorious beacon of light
    Dec 2003
    San Clemente, Ca
    Rep Level
    172
    Rep Power
    10
    Re: Class 10 Motor Combinations
    Call Adam Wik in las vegas he owns Wiks Racing he will piont you the right way.
    Dakar Finisher Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman has much to be proud of Will_Higman's Avatar
    Dec 2001
    Newport Beach California USA
    Rep Level
    1224
    Rep Power
    24
    [QUOTE=FlyHiFlyLo7]What do you think is the best engine combo to run in a class 10, 2 seater.
    Wiks Honda!
    Will Higman
    Loyal jamoffroad is an unknown quantity at this point
    Dec 2004
    thousand oaks ca
    Rep Level
    Rep Power
    best motor comb for class ten is LS1 and step up to classs 1 . or spend all your money on motor work and rebuild every race.
    Elite zjohnson is a splendid one to behold zjohnson is a splendid one to behold zjohnson is a splendid one to behold zjohnson is a splendid one to behold zjohnson is a splendid one to behold zjohnson is a splendid one to behold zjohnson's Avatar
    Dec 2003
    Encinitas, CA
    Rep Level
    571
    Rep Power
    15
    Depends upon the power and reliability issues you are willing to face. If you want liquid cooled, go with a Kroyer, torque monster for a 10 car, but very $$$$. Otherwise, I'd say go with the air cooled 2 liter, great motor, lots of torque and learn how to drive it . . .
    You can't fix stupid - Ron White
    Spam Whore Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker has a brilliant future Fourstroker's Avatar
    Jan 2004
    Garden Grove, CA
    Rep Level
    1804
    Rep Power
    33
    Quote Originally Posted by zjohnson
    Make sure that if you go air-cooled that you go with a Type 4 - 2 Litre. The Type 1 does not have the torque.
    Kevin Martin * 2005 B1K Finisher * BALD EAGLE RACING * BITD #1197 / MORE/SNORE #1297
    Forum Junkie ntsqd is a jewel in the rough
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    From memory the T4 2000cc uses a 66mm stroke while the T1 1600cc uses a 69mm stroke and most of the ~2.0 T1's employ a stroker crank.
    My opinon is worth what you paid me for it.
    Dec 2003
    North Mexico
    Rep Level
    13000
    Rep Power
    157
    Quote Originally Posted by jamoffroad
    There is a fine line between the two. However, I think I might have the right power to weight combo for the lower horsepower deal.
    what a dick
    Dicks.
    Jan 2004
    Garden Grove, CA
    Rep Level
    1804
    Rep Power
    33
    Quote Originally Posted by ntsqd
    The tType 4 @ liter uses a 72 Crank and 94 pistons. You can do exactly the same combo with a Type 1 but you will get less torque. Alot less
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    Quote Originally Posted by Fourstroker
    How is that?
+ Reply to Thread
  1. class 1 motor
    By asallenbach in forum Shop - Engine
    Last Post: September 28th, 2008, 21:06
  2. SS Class 9 and C9 Motor For Sale
    By TauMau in forum Class 9
    Last Post: September 23rd, 2008, 18:00
  3. Class 10 motor
    By rockstacker in forum Shop - Engine
    Last Post: August 4th, 2008, 17:11
  4. Class 10 - 4ag Motor????
    By jzember in forum Shop - Engine
    Last Post: April 22nd, 2007, 01:57
  5. Cost of Class 12 motor & trans
    By TCPRacing in forum Desert Racing
    Last Post: January 15th, 2007, 00:01
Bookmarks
