+ Reply to Thread
Results 1 to 4 of 4
Thread: Dual Battery Location in the Rear......
    Fresh Blood lump-dog is on a distinguished road lump-dog's Avatar
    Dec 2004
    Visalia, CA
    Rep Level
    13
    Rep Power
    I want to move my dual battery setup to the bed up my 2001 supercrew. I don't want to give up bedspace by simply throwing them in the bed. Does anybody have any suggestions before I waste time reinventing the wheel? I though about tucking them away neatly under the bedsides, but not sure if there's enough room. Also thought about removing the OEM spare tire bracing between the frame rails and placing them under the bed, as far back as I can put them. Or possibly hiding them under the spare tires if I decide to lay them flat. Has anybody been down this road? Post pics if you got 'em.
  2. Supporter of the Site
    Familia la2baja has much to be proud of la2baja has much to be proud of la2baja has much to be proud of la2baja has much to be proud of la2baja has much to be proud of la2baja has much to be proud of la2baja has much to be proud of la2baja's Avatar
    May 2005
    LA CA
    Rep Level
    882
    Rep Power
    18
    Re: Dual Battery Location in the Rear......
    I have seen a pretty clean set up. If you aren't against cutting into the bed, you can cut out a small piece of the bed on the pasenger side front corner. Then make (or have made) a battery case that can slide right into the rectangular hole in the bed. The battery tops end up flush or just below the bed floor. You have complete use of the bed space and the side wall of the bed body should easily cover the battery box from view outside the truck. You'll have you batteries in the bed. You'll have all your bed space, and you can easily access the batteries for mtce. or changing later.
    I would not suggest moving them much farther from the cab. The spare tire space at the rear of the truck is to far away from the altenator and running systems. You will lose voltage over that length of cable.
    Dec 2004
    Visalia, CA
    Rep Level
    13
    Rep Power
    Thanks for the reply, I'll explore that option tomorrow.
    Anyone else?
    Forum Junkie ntsqd is a jewel in the rough
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    That would depend on the cable size and how you've run the ground. Over that length the frame is NOT a good enough ground conductor and that is where most people get into trouble. Not with the size of the positive cable. The various welds in the frame rails of modern trucks are all points of resistance and they can & do add up to a potentially significant voltage drop. Even from the front of the bed I would highly recommend that you run a same size ground cable from the battery/ies to the engine block. From the spare tire area it would be a requirement.
    My opinon is worth what you paid me for it.
+ Reply to Thread
  1. Dual battery charging question
    By OffRoadGeorge in forum Shop - Electrical
    Last Post: January 15th, 2010, 19:29
  2. Electrical Guru's: Dual Battery Question....
    By lump-dog in forum Shop - Electrical
    Last Post: August 27th, 2005, 23:19
  3. dual battery and electrical question
    By slimjim in forum Shop - Miscellaneous
    Last Post: November 23rd, 2003, 12:09
  4. dual battery setup
    By bandikook in forum Shop - Miscellaneous
    Last Post: February 20th, 2003, 05:49
  5. rear shock mount location???
    By singlehanded in forum Shop - Miscellaneous
    Last Post: September 27th, 2002, 15:01
Bookmarks
