October 23rd, 2005, 15:39
#1
Radio help
sent my radio to PCI, they say it checked out OK. I can hear loud and clear when someone calls to me but they can only VERY faintly here me and thats if they are less than 20 yards away. other wise they can hear me hit their radio but hear nothing.
I cant find anything for the life of me. Know anyone in Phoenix that is good at troubleshooting the whole system?
October 23rd, 2005 15:39
# ADS
Join our community today |
October 23rd, 2005, 16:43
#2
Re: Radio help
If the radio is fine, then what about your coax? I know they're not supposed to be coiled in too tight of a radius. Is the connection at the back of the radio good? It can only be so many things if the radio is good...
October 24th, 2005, 13:36
#3
Re: Radio help
I seen the coax smashed in many race cars under zip ties. Also cuts going between panels and bars. If that is all good, your ant. mount may not be propely grounded (paint or rust) last thing. the ant. it self could be bad in the coil or the coection to the whip. You should buy an SWR meter or barrow one and test.
October 24th, 2005, 16:30
#4
Re: Radio help
thanks guys, I'll re look at all that again and check the coax coil, I know I have a lot of extra and switch antenna's.
October 24th, 2005, 16:57
#5
Familia
Re: Radio help
I would also question your mic. Did you send that to PCI with the radio? If you hear them and they don't hear you with a radio freshly checked out I would check the mic. The mic and the line to the mic probably take the most abuse.
October 25th, 2005, 07:26
#6
Re: Radio help
dont have a mic really, just two buttons, one for driver and one for navigator, but will check those connections and buttons, thanks
October 25th, 2005, 08:19
#7
Re: Radio help
We had the same problem with our radio/intercom setup. Turned out that the factory supplied radio handset used an electret/condenser mic, but the standard mic for helmets and headsets is a non-powered mic (not sure what the proper name of that style is). Since the signal from a condenser mic is substantially stronger, I had to rig up an amplifier to put inline with the helmet mics. Haven't had any problems since then!
Dave Grundman #300 Crew Chief
October 25th, 2005, 10:11
#8
Re: Radio help
Who's helmet wiring set-up is it? It may just need a different mike installed. Did you try someone elses helmet or headset with the system? If it's the wrong mike it will sound weak. PCI uses a dynamic mike in their stuff.
October 25th, 2005, 10:35
#9
Re: Radio help
We had the same thing happen with our system. Turned out to be the coax got crushed.
October 25th, 2005, 12:30
#10
Re: Radio help
tried 4 helmets, and two head sets, plugged into driver and passenger side, radio, helmets and head sets all supplied by PCI and worked in my prerunner with the same setup all from PCI.
looking more and more like cable issue.
