Anyone else have this problem? Scott at PCI told me to make sure the intercom and race radio are all grounded to the same spot but that didn't work. He is prerunning in Baja so I don't know if he will be back with more ideas before I leave so I thought I would ask on here if anyone has dealt with this.
I have the 4-link intercom, the ground wire and the other ground fromt the corner of the box are grounded in the same spot as my race radio. when the race radio is turned off you can only hear a light engine noise when the squelch is turned off or when you talk. Once I turn the race radio on the noise gets pretty bad regardless if you hear the radio through the intercom or not.
To make it worse I wired in my XM radio to the intercom and when that is on the noise is crazy....
I think I might try one of those inline power noise filters.
any other suggestions?
Bookmarks
