Results 1 to 6 of 6
Thread: Problem with my Lowrance 480c
    May 2003
    Huntington Beach, Ca
    All of a sudden, my Lowrance 480c baja is giving me a window that says, "GPS module not responding".... can anyone point me in the right direction to fix this issue..... it was working fine.
    "Lynn, copy Rose, through the Josh Relay?" "cómo se dice, light headed?"
    Accepted
    Jul 2001
    The brown cloud called The Inland Empire
    Re: Problem with my Lowrance 480c
    When mine said that, the antenna didn't have power. Little red and black wires.
    Senior gwm's Avatar
    Aug 2003
    El Cajon, CA
    Mine was a bad cable. The last prep person had doubled it back to shorten it and then zip tied it down - hard. Little wires are fragile things. If you know somebody who has a compatable unit switching out the module (antenna) and the cable as a test might be worth the time and hassle. Both are too expensive to buy without knowing for sure. (I figured that out the hard way.)
    George Milke
    "It's better to die on your feet than live on your knees"
    Emiliano Zapata
    Elite ShaneR's Avatar
    Apr 2004
    Live AZ/ work Las Vegas
    Yes that error message means it is not getting a signal from the anteana. Could be a bad anteana or the wiring going to the anteana. Also check the connector that hooks up to the anteana as we have had ours come loose there at the plug, wires kind of pulled out of the plug but we were able to fix it with out replacing it.
    Shane Robinson
    Racing is all about having fun, winning is just the most fun!!!!!!
    May 2003
    Thanks guys
    RDC Addicted Cadwell's Avatar
    Feb 2005
    Anaheim Hills, CA
    yeah, mine shows me north of where i'm actually at! when i'm on my street it shows me on the next street up. and sometimes it doesn't even show me on a street! But I do love this GPS!
    My quote from the baja1000 thread.....
    Robby never rolls.......the earth just rotated due to how much horsepower he has.
  1. GPS Help- Lowrance 480C
    By Calilove1 in forum Shop - Electrical
    Last Post: April 5th, 2009, 21:03
  2. lowrance alt.
    By Herbaljedi in forum Shop - Electrical
    Last Post: February 26th, 2009, 14:23
  3. Lowrance Baja 480C
    By BajaBronco13 in forum Shop - Electrical
    Last Post: October 8th, 2006, 15:20
  4. Lowrance 480c - What size memory card?
    By RRose in forum Shop - Electrical
    Last Post: August 21st, 2006, 15:40
  5. Lowrance GPS help
    By tkr in forum Shop - Miscellaneous
    Last Post: April 2nd, 2003, 07:23
