Results 1 to 6 of 6
Thread: ground to frame or engine block?
    Accepted wetmonkey's Avatar
    Oct 2004
    Imperial, CA
    I'm relocating my battery to the rear of my Explorer. Should I run a cable from the NEG battery post to the frame or should I run the cable to the engine block? Or does it even matter? I heard somewhere to run it to the engine and then run one off of that to the frame. What's the difference? or is there a difference?
    "Same ol' s**t, different race"
    Loyal weldithot79's Avatar
    Sep 2005
    Buckeye, AZ
    Re: ground to frame or engine block?
    depends on if your engine is isolated by rubber factory motormounts or not. If it is isolated ground to the block, if you have solid motor moounts I think you can ground anywhere on the frame.
    Loyal sandking's Avatar
    Jan 2005
    corona, ca
    I would run a ground to the chassis from the battery, then a ground from the motor to the chassis. The bigger the wire, the better.
    Oct 2004
    Imperial, CA
    As far as I know, it still has the factory motor mounts. The original cable went from the batt to the engine and had a smaller one running off of that one to the frame. What's the worst case senario if I ran it to the frame and not the engine, or the engine and not the frame?
    Sep 2005
    Buckeye, AZ
    To be safe do like sand king said, run a ground to the frame and then one from the frame to the block. The heavier the wire the better, and make sure you have a good connection at all points.
    Oct 2004
    Imperial, CA
    Quote Originally Posted by weldithot79 View Post
    i think i'll do just that, thanks.
  1. Pants off the ground!
    By Petepecas in forum Whatever - General Discussion
    Last Post: January 20th, 2010, 09:03
  2. Ground Flyer
    By Ground Flyer in forum Hello, My name is _______
    Last Post: July 14th, 2009, 14:34
  3. I need an engine block chromed
    By DTA 55 in forum Shop - Body and Paint
    Last Post: August 26th, 2008, 17:38
  4. small block / big block???
    By roach in forum Shop - Engine
    Last Post: March 24th, 2005, 02:32
  5. Off the ground !!!!!
    By Big_Rich in forum VORRA
    Last Post: December 19th, 2002, 19:40
