+ Reply to Thread
Results 1 to 5 of 5
Thread: Rear Diff Issue
    Fresh Blood FordFreak is on a distinguished road FordFreak's Avatar
    Jun 2002
    Orange, CA
    Rep Level
    10
    Rep Power
    10
    Exclamation Rear Diff Issue
    First off let me apologize for the length of this post. I need some re-assurance on this issue. I had my '99 F-150 Re-geared to 4.56 a little over 3 years ago now. I have 35" tires, so I went to the new gears. I went to a reputable shop (I will not name where) to have them installed. I was happy with the price and work. It was recommended that I change my fluid in the diff in another 2k mile or so. I did so without any problems. 11 months (and 9k miles) later my ABS light came on and I noticed a leak in the rear diff with dents all over the cover. I took it back to the place that installed my gears and after new bearings, posi, and ABS sensor I was told that a ring gear bolt had broken and caused the problem. This past week while driving I noticed a couple of kachunks coming from the rear of the truck. I took a look at the diff and saw what looked to be dents. I just changed the fluids and when I opend the diff I found what looked like to be a backed out ring gear bolt. What are the chances of this happenening? I assume that is is highly unlikely. This made me think that the first problem I had may not have just been a fluke thing. I don't really want to go back to the shop and have them make sure everything in the rear is ok. What should I do?
    Adam
    You wanna see if there is life after death? Touch my truck and find out!!
  2. Supporter of the Site
    Racer matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton's Avatar
    Feb 2003
    Yorba Linda, CA
    Rep Level
    2294
    Rep Power
    38
    Re: Rear Diff Issue
    red locktite!!
    Fresh Blood ASITool is on a distinguished road
    Sep 2004
    Redlands, CA
    Rep Level
    10
    Rep Power
    Re: Rear Diff Issue
    Had a similar situation changing ratios -- different ring gears requiring different diameter bolts. Shop used old bolts which were too small and eventually sheared.
    __________
    Craig
    Elite 14802 is a glorious beacon of light 14802 is a glorious beacon of light 14802's Avatar
    Nov 2004
    Scottsdale, AZ
    Rep Level
    189
    Rep Power
    10
    Re: Rear Diff Issue
    I had a fairly decent shop(I thought) do a R&P swap on a old suburban I had. The shop called to tell me that 2 of the bolts were sheared off in the carrier. So I went down to the so called "shop" and found out that the numb-nuts(impact gun still in hand)did not know about the left-hand threads...
    If for some reason the shop you took it to forgot the direction..It might have stretched the bolt for a latter failure???
    Elite sickrick is a splendid one to behold sickrick is a splendid one to behold sickrick is a splendid one to behold sickrick is a splendid one to behold sickrick is a splendid one to behold sickrick's Avatar
    Mar 2005
    Elk River Minnesota
    Rep Level
    453
    Rep Power
    12
    Re: Rear Diff Issue
    Quote Originally Posted by matt_helton View Post
    red locktite!!
    Red locktite.
    Sickrick, and the Displaced Desert Racers.
    Not sick in that "extreme" kind of way, its more of a weak stomach thing.
    Rick Snell.
+ Reply to Thread
  1. What diff to use for a rear A-arm prerunner
    By D.Mavis in forum Shop - Driveline
    Last Post: July 21st, 2010, 23:20
  2. Subaru rear diff question
    By TwistedMetal in forum Shop - Driveline
    Last Post: December 10th, 2008, 19:01
  3. Rear End Diff Vent
    By Iggle in forum Shop - Driveline
    Last Post: October 31st, 2007, 12:08
  4. Aluminum rear diff cover swap...
    By spalind in forum Shop - Driveline
    Last Post: October 15th, 2007, 07:25
  5. Rear Diff Cover
    By John_Bitting in forum Shop - Miscellaneous
    Last Post: August 21st, 2001, 17:50
Bookmarks
