Results 1 to 8 of 8
Thread: need advice to build a-arms
    Prospect
    Oct 2006
    Harwich, Mass
    Was woundering if anyone could give me a few tips on how to build a-arms. I can tig weld very well and need to know sometricks to find out the geometry.
    Santa Maria, CA
    Re: need advice to build a-arms
    make the spindle slightly taller than the inside pivot disance. Make sur eyou gain caster as it compresses and looses caster as it droops, but make sure it nevers goes past 0 caster. Also make sure not to have any positive camber throughout the cycle. There's a lot of info already on the site. just search and read a lot.
    Elite aiiraciing's Avatar
    Jan 2005
    OC
    Quote Originally Posted by welderbob View Post
    Check out this thread
    http://www.dezertrangers.com/cgi-bin...ST;f=2;t=24124
    -Brian
    Elite ErikShallbetter's Avatar
    Minnesota
    Quote Originally Posted by 85yota View Post
    I have been told by some very knowledgeable people in the industy that you should forget anything you ever learned, knew, or heard about caster gain. I do not build it into any of my suspension systems.
    Read as much as you can before you start. Everything in a suspension design is a compromise. Changing one thing effects several things. Better this equals worse that. Determine what you feel is most important, caster/ camber curves, bumpsteer, ackerman, scrub radius, track scrub...ect. and design for those areas.
    Good luck with the build!
    Forum Junkie FABRICATOR's Avatar
    Ventura County, CA
    That's a good simple rule..."Better this equals worse that."
    Support Our Troops ------ If you can't stand behind them, feel free to walk in front of them.
    If your looking for something blingy and complex, I'm delighted to disappoint you!
    "[Nye Frank] built the best, and never looked to anyone for recognition, the mark of a true man, one of the last true cowboys of our sport!"
    "The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge"
    If you are racing a fair race...your strategy sucks!
    Fresh Blood BioMax's Avatar
    Hemet, Ca
    I've built a truck with castor gain (anti-dive) I'll never waste my time again! A small amount of anti-dive = way too much castor change over 24" of travel.
    Build you suspension idea out of cardboard and use thumbtacks for pivot points and find some geometry you like. Some of the top guys do it that way.
    Other than that, pay attention to the trucks that win and notice the difference between those and the trucks that don't work so well.
    -Bio Kustumz- Doing better work than monkeys for about a week now...
    Rookie RacinHam's Avatar
    Feb 2007
    Lancaster, CA.
    I started building a arms for my ranger and didnt know how to go about it. Thanks to everybodies input here it has helped me alot. Thank You.
    Feb 2007
    Mission Viejo
    Webbing in the right palces, heavy guage for those lower arms depening on application (.090- .188) and burn that baby hot with lots of rod. Don't be affraid to take your time welding with multiple passes. More is always better when it comes to welding.
  1. Building a-arms soon.. need pro advice on design.
    By Dirtrunner21 in forum Shop - Suspension & Steering
    Last Post: February 6th, 2011, 13:37
  2. Sportsman Toyota Teardown/Build up advice needed
    By dan200 in forum Shop - Miscellaneous
    Last Post: July 2nd, 2009, 17:37
  3. Replies: 0
    Last Post: February 22nd, 2008, 00:10
  4. Arms, Spindles, Link Pins - Any advice
    By wheezy in forum Shop - Suspension & Steering
    Last Post: July 24th, 2007, 08:55
  5. Looking for someone to build rear arms for a 10 car
    By Jeffers909 in forum Shop - Suspension & Steering
    Last Post: March 2nd, 2007, 20:49
