Results 1 to 10 of 20
Thread: optima red top battery...dead..reachargeable?
    Prospect
    Dec 2004
    Visalia, CA
    I have 2 optima red top batteries that have died, I have recharged for a short time (one night) they worked OK for that day. I wasn't able to drive the vehicle until 4 days later and they were almost dead...........wouldn't crank it over.
    Can these be charged up and good to go again or do they die in time like every other battery?
    RDC Addicted Chris_Wilson's Avatar
    San Diego
    Re: optima red top battery...dead..reachargeable?
    Red tops die like that. Use yellow tops. They work great for starting and survive deep discharges. I don't even know why they still sell the red tops.
    Forum Junkie 450grl's Avatar
    Jun 2006
    Chandler, AZ
    Oh....don't say that!!! I just bought a red top!!!
    Corry Weller
    2012 LOORRS Pro 4 Rookie of the Year
    2011 LOORRS SR1 Champion #810
    www.wellerracing.com
    May 2006
    Quote Originally Posted by urbanmx View Post
    Have you thought of the possibility that there might be something in the vehicle that is discharging the batteries ? I'd recharge the batteries and then disconnect them from the vehicle for a period of a couple of days and then reconnect them and see if the discharge problem still exists. Also, you might want to take the batteries somewhere and have them tested. There are some cool testers that will test not only voltage, but cranking power for a battery. It would be a shame to throw away good batteries only to discover that you have another problem.
    RDC Addicted 5racer's Avatar
    Jun 2003
    san jacinto calif
    i argree the red tops suck they more than likely will be no good if you have charged and they dident hold .thats if you dont have a draw in car easy way to find current draw is hook up battery then take neg post off hook test lite between neg and the chassie if it lites up you have a draw start pulling fuses tell it goes off and walla theres your culpret
    Loyal weldithot79's Avatar
    Sep 2005
    Buckeye, AZ
    I also had a brand new red top go dead on me. I have had the truck sitting for about 4 weeks with the battery isolated went to start the truck and nothing, is this common for red tops? The other red top, my backup, also Isolated, barely cranked the motor.
    RDC Addicted REEVESRacing's Avatar
    Jan 2004
    Encinitas, CA
    Thumbs up Re: optima red top battery...dead..reachargeable?
    Quote Originally Posted by weldithot79 View Post
    OPTIMA 800 # will pro-rate replace, they are good about it, think less than 1 yr. is free replacement, they replaced ours. Go to their website for the 800 #, then they send you to autozone to verify if the bat. will not hold charge. We run 1 red for starts and yellow aux. etc.
    Do aq search, lots of optima info on RDC. Good luck on replacements. We were stoked.
    Krittro Campbell Kritter's Avatar
    Quote Originally Posted by 5racer View Post
    Make sure to unplug all your accesories that pull a slight bit of power with the key off or you will be chasing your tail, by the above method.
    www.shockseals.com
    Jun 2003
    san jacinto calif
    accessories usually dont pull enough volts to lite up a test lite besides your dome lite just shut your door when testing.
    Junior ThriceGuy's Avatar
    Oct 2002
    Foothill Ranch, CA
    I purchased a yellow top for my prerunner since it sits my garage for long periods of not being run. I tried to start it yesterday and the battery was completely dead. The battery is only 2 months old. I thought the yellow tops could last long periods of no use.
  1. Battery terminal up front but no battery
    By mikebuff in forum Shop - Electrical
    Last Post: September 25th, 2007, 12:45
  2. New Optima Battery Question
    By RRose in forum Shop - Electrical
    Last Post: June 29th, 2006, 11:41
  3. Optima battery & stereo system?
    By sirhk100 in forum Whatever - General Discussion
    Last Post: July 25th, 2004, 20:50
  4. DEAD BATTERY
    By mustafa in forum Whatever - General Discussion
    Last Post: February 23rd, 2004, 00:02
