+ Reply to Thread
Results 1 to 7 of 7
Thread: Need Help with 94 Ford 4.0 OHV fuel & wiring
    Senior DesertLab is a name known to all DesertLab is a name known to all DesertLab is a name known to all DesertLab is a name known to all DesertLab's Avatar
    San Jose, Ca
    Rep Level
    351
    Rep Power
    10
    Need to get the DL7 running ASAP. I need some help with a few things. Here it goes. 1994 4.0 OHV stock motor / C4 / Stock Computer.
    1. Fuel System:
    How do I run the fuel & fuel return lines from the stock intake manifold to the cell/pump? Do I use the short stock lines from the intake manifold and get a custom hose with the stock ford compression fitting on one end? Can I convert to an AN fitting right off the stock intake manifold? What threads into the intake manifold? Metric, AN, Pipe fitting, & Size?
    2: Computer
    Anyone have any idea "Exactly" which wires are needed to make the motor run from the stock motor harness, to the computer, ect?
    3. Are there a few sensors that need to be bypassed, such for the stock A4ld Tranny, Speed Sensor, or a crank sensor? If so, how do you bypass them?
    4. I seem to remember hearing something wierd regarding the wiring to the Stock Ford Alternator, something to do with the computer or jumping a wire mabey. Any idea?
    5. Any other general tips, tricks, ect. I need to get the DL7 running ASAP.
    6. Can somesone email me a wiring diagram?
    Thanks in advance! ~josh
  2. Supporter of the Site
    Mini Metal MOD DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing's Avatar
    Jan 2003
    San Diego
    Rep Level
    2637
    Rep Power
    42
    Re: Need Help with 94 Ford 4.0 OHV fuel & wiring
    I've done the fuel system on different trucks both ways in the past. It mainly depends on how you want your system set up. You can buy the Ford fittings and EFI fuel line, but I wouldn't trust this Ford fuel line for racing applications. Which end of the line has the female compression fittings on it, Intake manifold side or fuel tank side. If you have any photos of the stock fuel fittings you're referring to, I may be able to help you out.
    RDC Addicted johnnyweb is a splendid one to behold johnnyweb is a splendid one to behold johnnyweb is a splendid one to behold johnnyweb is a splendid one to behold johnnyweb is a splendid one to behold johnnyweb is a splendid one to behold johnnyweb's Avatar
    Jan 2003
    Gilroy-Shop
    Rep Level
    616
    Rep Power
    19
    ive always left the stock line down to the stock filter in the frame rail. then converted it from the inlet side ot the filter back to the fuel cell. as far as the fuel pump electrical and the alternator goes are going to use the stock relays and fuse box? stock ignition switch? etc. the tranny electrical wires will not effect the running of the motor as well as the VSS in the rear end. cut them out and seal them up. a wiring diagram would be nice but not neccesary. it can be done by process of elimination and tracing wires back to the ignition switch etc.
    JOHNNYWEB
    John Webster
    Johnny's Custom Motorsports
    BITD Team #8118
    Wham Spore movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt has much to be proud of movindirt's Avatar
    Apr 2005
    24.5mi from Timbuctoo, Ca
    Rep Level
    1451
    Rep Power
    26
    I was going use this Russell (click here) fitting to run lines to a cell on my 97 Ranger 4.0...
    Apr 2005
    Rep Level
    1451
    Rep Power
    26
    Wiring diagram:
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	wiring 94 ranger008.jpg‎ Views:	48 Size:	358.1 KB ID:	19097
    San Jose, Ca
    Rep Level
    351
    Rep Power
    10
    Thanks Guys. Keep the info coming.
    Jan 2003
    San Diego
    Rep Level
    2637
    Rep Power
    42
    Dug up this link to the place I bought the fuel fittings. He carrys the large and small springlock fittings, EFI tubing and the Russell AN fittings.
    http://www.ronmorrisperformance.com/...Store_Code=rmp
    As far as the computer wiring goes, try to keep the MAF and O2 sensors connected. If you don't the computer goes into failure mode, the engine will run rich and you lose power and fuel efficiency. Found that out from experience.
+ Reply to Thread
  1. Ford Econoline F350 wiring diagrams
    By Snowy in forum Shop - Electrical
    Last Post: October 29th, 2008, 14:11
  2. saftey locking wiring brake lines/fuel line fittings
    By reverhart in forum Shop - Safety
    Last Post: June 12th, 2008, 21:48
  3. 1994 ford ranger wiring harness!
    By evan94ranger in forum Shop - Electrical
    Last Post: May 1st, 2008, 17:51
  4. Replies: 7
    Last Post: April 26th, 2007, 13:00
  5. Ford wiring question and link to our truck
    By Brice in forum Shop - Miscellaneous
    Last Post: July 3rd, 2003, 13:53
Bookmarks
