Results 1 to 4 of 4
Thread: LED Alternator Light
    Loyal ffjerm's Avatar
    Nov 2004
    Apple Valley, CA
    Lightbulb LED Alternator Light
    OK....I'd like to use an LED as an idiot light for the ALT on a VW, but I know this won't work with traditional wiring. I've heard that you can do this with a relay and resistor. I'm guessing you'd need a normally closed relay that is opened with the ignition switch then closed when the alt starts charging, but I can't figure where the resistor comes into play. Does anyone here have any experience with this? Any info would be great. I've tried an interenet search, but haven't got a straight answer.....
    Thanks in advance....
    Stand on it, Stroker!!
    Oceanside, CA
    Re: LED Alternator Light
    yes you can do this no problem.. pm me for more info. i need to know what LED's you are using
    Senior Superfab's Avatar
    Dec 2004
    El Cajon, CA
    Just used a 220 ohm resistor so the current draw matched a light bulb. You need about a 1/2 amp minimum of draw to make the circuit work. Better to be a little more draw than less.
    Loyal TexasRacing's Avatar
    el paso,tx
    Hi Plumwire we are atemping to do the same thing on our 1600 can you explain the wire cuircut
    thanks lenny
    "It's not what you drive,but what drives you!"
  1. alternator idiot light
    By ruff ranger in forum Shop - Electrical
    Last Post: June 15th, 2010, 16:18
  2. VW alternator light question???
    By NTRoffroad in forum Shop - Electrical
    Last Post: February 15th, 2009, 18:30
  3. Big Alternator
    By RacrDude in forum Shop - Electrical
    Last Post: August 28th, 2007, 22:21
  4. Alternator
    By 516racer in forum Shop - Electrical
    Last Post: June 11th, 2005, 20:56
  5. Who's Alternator
    By scott in forum Desert Racing
    Last Post: January 19th, 2005, 18:58
