+ Reply to Thread
Page 3 of 4 First 1 2 3 4 Last
Results 21 to 30 of 34
Thread: dual battery setup
  1. #21
    Forum Junkie hoeker is a splendid one to behold hoeker is a splendid one to behold hoeker is a splendid one to behold hoeker is a splendid one to behold hoeker is a splendid one to behold hoeker is a splendid one to behold hoeker's Avatar
    Oct 2002
    holland, MI
    Rep Level
    541
    Rep Power
    18
    Re: dual battery setup
    many of the CORR trucks run a red top(regular) and yellow top (deep cycle i think) are these what your refering too? if so, i am also curious. i can see the advantage of a deep cycle in a racing application if you loose the alt, but then they should both be deep cycle? i think i'm going to save the 40lbs, and just run one bat. with enough amperage alt. to run everything on my truck. 40lbs / vs 2 hp - tough choice!
  2. Supporter of the Site
    Forum Junkie ntsqd is a jewel in the rough
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    Starting batteries aren't well suited to being deep cycled, it tends to kill them faster than otherwise. Deep cycle batteries aren't well suited to discharging starting current levels.
    If it's a race truck, particularly one with a small displacement engine, I would seriously weigh battery life against deep cycle reserve. If you have a 12:1 400 inch V8 then I'd have to say red top only otherwise having the sole battery being a yellow top MIGHT be an advantage.
    Both the Yellow and the Red tops are listed as having the same reserve time. If you tend to kill alts mid race then a yellow top would be a sound choice.
    To do a red top for start - yellow top for everything else wouldn't be too difficult of a wiring job. In a race vehicle I doubt I'd do it w/o a really good reason. I'd be more likely to do it in a chase/play vehicle.
  4. #23
    Forum Junkie Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis has a reputation beyond repute Tom_Willis's Avatar
    Oct 2001
    18th Flr, Wilshire Blvd. L. A.
    Rep Level
    5998
    Rep Power
    74
    That's a lot of valuable information. Good to know that it's not as complicated as it seemed at first, there aren't any equations to do. I still can't figure out one small detail. Who turns off the light in my fridge when I shut the door?
    I live my life one paycheck at a time
  5. #24
    Ironman Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani's Avatar
    Carlsbad, CA
    Rep Level
    8840
    Rep Power
    107
    You turned off the light when you shut the door. And, you should be doing the same thing in your truck if you run dual batteries. What I mean is that you should be using a manual two battery switch (I have never seen a serious race truck that does not use one) so that you can select either battery or both. Not only can you manually manage the use of your batteries and their charging, but it is a good safety item to have, should you get wadded up. Hide it's location to a degree and your average idiot can't rip your truck off as easily. You can even get one that locks with a key. Check out: <A target="_blank" HREF=http://marineengineparts.com/shopsite_sc/store/html/page50.html>http://marineengineparts.com/shopsite_sc/store/html/page50.html</A>
  6. #25
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    Hella makes a battery switch similar to the Blue Seas unit with the removable key in Ramsey's link.
    My local West Marine carries the Blue Seas switch and project "Scrusty" got one.
  7. #26
    Accepted bajaruner11 is just really nice bajaruner11 is just really nice bajaruner11's Avatar
    Apr 2002
    The Deserts bottomless pit, CA
    Rep Level
    149
    Rep Power
    11
    Just a note to everyone regarding the hella battery switch. It's junk! and I'm referring to the marine switch. Over time I have had the opportunity to see 3 of these die out in short time. I would go with a true marine switch such as "Perko" or "Bluesea".
  8. #27
    Checkers or Wreckers michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis has a reputation beyond repute michael_loomis's Avatar
    Mission Valley, Ca.
    Rep Level
    14080
    Rep Power
    172
    make sure you get one with AFD or else you'll screw up your alterator when you flip the switch and the engine is running.
  9. #28
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    Sometimes called an "alternator protection diode" in sales literature.
    <hr></blockquote>
    I'm not convinced this will happen the first time this is done, but why take the chance ?
  10. #29
    Junior mxjeremy is on a distinguished road
    anaheim, ca
    Rep Level
    10
    Rep Power
    11
    If this is for a racing application, especially short-course, then why run a battery at all? Save 80lbs instead of just 40. If you are worried about starting after a stall (OMG,why would you stall?), then you could rig up some pneumatic starter mechanism. Use a section of your rollcage as air tank, and fill it up between races. After all, my cr250 doesn't need a battery, and it kicks butt.
    late.
  11. #30
    Sep 2001
    Here
    Rep Level
    98
    Rep Power
    15
    I have a real problem with using the cage to hold compressed air. There is a lot of energy in compressed air and a cage is not designed to properly contain that pressure. I suspect that if a tech guy figured out what you were doing that he would make you remove it.
+ Reply to Thread
  1. Dual battery charging question
    By OffRoadGeorge in forum Shop - Electrical
    Last Post: January 15th, 2010, 19:29
  2. Dual Sport Suspension Setup
    By hobie164 in forum Shop - Suspension & Steering
    Last Post: October 8th, 2007, 15:58
  3. Dual Battery Location in the Rear......
    By lump-dog in forum Shop - Electrical
    Last Post: October 5th, 2005, 08:19
  4. Electrical Guru's: Dual Battery Question....
    Last Post: August 27th, 2005, 23:19
  5. dual battery and electrical question
    By slimjim in forum Shop - Miscellaneous
    Last Post: November 23rd, 2003, 12:09
Bookmarks
