+ Reply to Thread
Results 1 to 6 of 6
Thread: regearing a 2.3 5 speed help
    Prospect DA//16 is on a distinguished road
    ca
    Rep Level
    10
    Rep Power
    hi,
    i am regearing the ring and pinion on my ford ranger 2.3l 5 speed with 32's, what is the right ring and pinion gear ratio?
    thanks for the help,
    nick
  2. Supporter of the Site
    ca
    Rep Level
    10
    Rep Power
    Re: regearing a 2.3 5 speed help
    any help?
    Senior Polarcub is a glorious beacon of light Polarcub is a glorious beacon of light Polarcub is a glorious beacon of light Polarcub's Avatar
    May 2007
    Quail Valley CA
    Rep Level
    242
    Rep Power
    7
    My brother is running 4.10s in his ranger with either 32 or 31 tires. It is not bad. I would prefer 4.56/4.88 or even 5.13 but alot depends on what your ranger is used for beside s a toy? 4.56 would be doable on the street and that motor will push some rpms but the 4.10s are good too.
    Forum Junkie mrmatt is a splendid one to behold mrmatt is a splendid one to behold mrmatt is a splendid one to behold mrmatt is a splendid one to behold mrmatt is a splendid one to behold mrmatt's Avatar
    Mar 2006
    garden grove,ca
    Rep Level
    434
    Rep Power
    13
    Yes I run a 4.10 with 31" tires. If you are going to drive the truck on street alot I would not run more than a 4.56 w/32". If it is off-road only then I would go 4.88 ish. I would also suggest adding at least posi.
    Kaveman Motorsports on Facebook- http://www.facebook.com/kavemanmotorsports
    Kaveman Motorsports on YOUTUBE - http://www.youtube.com/user/kavemanmotorsports
    Loyal lowdownndirty is a glorious beacon of light lowdownndirty is a glorious beacon of light
    El Cajon Ca
    Rep Level
    152
    Rep Power
    7
    4.56 and 31's work out about perfect for a daily driver with the 2.3. 32's will be fine too. about 3,000 rpm at 75
    33's then I would want 4.88's
    Prospect EvanNumberSeven is an unknown quantity at this point EvanNumberSeven's Avatar
    Apple Valley, CA
    Rep Level
    Rep Power
    Your truck is counting on the right gear ratio to perform with the least amount of load with the best efficiency. You just cant eyeball numbers and slap whatever gear ratio you want into a daily driver. Because It takes a toll on your whole ***** from computer to exhaust. (depending on the year) with the 5spd 2.3 and you want to run 32s you would need 410s if you want to do it right.
    Quote Originally Posted by lowdownndirty View Post
    You cant put 4.88s in a 7.5
+ Reply to Thread
  1. Regearing the front of my bronco...
    By SC150 in forum Shop - Driveline
    Last Post: November 6th, 2009, 14:02
  2. Ford 8.8 regearing questions
    By coooray619 in forum Shop - Miscellaneous
    Last Post: December 7th, 2004, 11:10
  3. Regearing Question
    By Josh_Bethmann in forum Shop - Miscellaneous
    Last Post: January 4th, 2004, 23:53
  4. rear end regearing
    By empire231 in forum Shop - Miscellaneous
    Last Post: August 15th, 2003, 10:10
  5. Regearing a TRD locker
    By Dylan in forum Shop - Miscellaneous
    Last Post: September 3rd, 2002, 16:07
Bookmarks
