Results 1 to 10 of 13
Thread: RCI Circle track fuel cell, yea or no?
    Powered by Optima philofab's Avatar
    Jun 2006
    JRod's livingroom.
    I'm in the need of a fuel cell for my Toyota, and I see a lot of people running these on their prerunner trucks. Good or bad idea? I looked in my book and I don't see any reason it wouldn't pass SCORE tech. I'd like an off-road specific cell but this seems to be half the price.
    http://store.summitracing.com/partde...5&autoview=sku
    ponca city, ok
    Re: RCI Circle track fuel cell, yea or no?
    looks ok to me.
    sharp tools throw big chips
    Racer matt_helton's Avatar
    Feb 2003
    Yorba Linda, CA
    i had the jazz version in my toyota and it worked great!
    Santa Maria, CA
    just ordered one for a friends truck. they work good. I ordered it from jegs tho. $5.00 cheaper and they had it in stock.
    Loyal random hero's Avatar
    Oct 2007
    Alamosa, CO
    would this pass score, bitd, more ect... rules?
    Forum Junkie 1450-ranger's Avatar
    Jun 2004
    CA
    Quote Originally Posted by random hero View Post
    Yes, it will pass.
    Nov 2004
    San Diego
    Quote Originally Posted by McClintock View Post
    Yes, it will pass.
    Actually I dont think that fuel cell will pass Score or BITD rules. The cell in the attachment above was a steel can with a poly tank enclosed without any form of internal baffling. (aka foam)
    Score's rules say;
    Safety fuel cells shall consist of a bladder enclosed in a smooth skinned container. The container may be constructed of 20ga. steel, .060 aluminum or .125 marlex. All fittings must be built into the skin and bonded to the skin as an integral part of the tank or mechanically sealed by an O-ring and counter ring system by either a flat joint or an O-ring. "Internal Baffling is mandatory in all fuel cells." Bladder construction shall be of nylon or Dacron woven fabric impregnated and coated with a fuel resistant elastomer.
    Physical property specs;
    Tensile strength 450lbs minimum
    Tear strength 50lbs. minimum
    Puncture test 175lbs. minimum
    These physical properties must be maintained throughout all areas of the finished bladder, including seams, joints and fittings.
    "If off-road racing is outlawed only outlaws will race off-road."
    Senior baja stu's Avatar
    Sep 2005
    Menifee, CA
    I had a Jaz fuel cell in my last pre-runner and it came with foam in it. I belive that Jegs sells Jaz.
    http://www.jazproducts.com/pro_sportII_fc.html
    Cross-threading is just as tight as Loctite
    Dec 2007
    Sandy Eggo, CA
    I can't speak with any authority about whether or not it would be SCORE tech-legal. But I can tell you that I've used RCI Fuel cells in circle track projects in the past and have nothing but good things to say about them. They are very good value for the money.
    Marshall
    (Not the Big Oly guy)
    Senior wrightracing.net's Avatar
    Those fuel cells wll pass as long as you put foam in them if they did not come with it. The other rule that can be an issue with this cell is that it has to be remote filled from outside the car/truck. I think they do have fill plates in a smaller size than our 6x10 plates we use on ATL or Fuel safe cells.
    David Wright - Wrightracing.net - Complete-fab.com
  1. fuel cell
    By bajahucks in forum Class 9
    Last Post: January 28th, 2009, 09:46
  2. Fuel cell
    By SPIDER in forum Shop - Safety
    Last Post: September 18th, 2008, 12:33
  3. Fuel cell
    By ElkinsRacing in forum Class 9
    Last Post: September 10th, 2008, 18:04
  4. Hardin on the circle track?
    By elcaprerunner in forum Pavement Racing
    Last Post: May 11th, 2003, 11:56
  5. Fuel cell ?
    By Azdesertracer in forum Shop - Miscellaneous
    Last Post: January 14th, 2003, 19:24
