+ Reply to Thread
Results 1 to 6 of 6
Thread: Engine Questions
    Prospect Mullen-shoe is on a distinguished road Mullen-shoe's Avatar
    Aug 2005
    Phoenix, AZ
    Rep Level
    10
    Rep Power
    Engine Questions
    Hi,
    I'll start with my disclaimer. I'm not good at mechanic work so bare with me.
    Here's my scenario followed by a couple of questions.
    My baja bug was sitting (in Phoenix) for about 8 months. I managed to fix a shifter issue. After changing the oil and running it "in place", I took it for a spin up the block. The engine did not run well and seemed to be loading up with fuel. I thought I might as well change the plugs and ignition wires. Again started it up and a 1/2 block later, I could keep it running by revving the motor but it will die when I keep the throttle down or try to go in any gear including reverse. The old Zenith carb on it is wet around it too.
    FINALLY my questions:
    Could "old" gas be the cause of this?
    Does the "wet" carb indicate some fixing?
    Is it worth fixing the old carb?
    What is a good replacement carb?
    It's an older bug and the motor was detuned before I got it to run Mexican gas in it.
    Thanks for any help and/or advice.
    -Chris
  2. Supporter of the Site
    Senior 43mod is a glorious beacon of light 43mod is a glorious beacon of light
    colusa california
    Rep Level
    175
    Rep Power
    Re: Engine Questions
    sounds like a stuck float/needle and seat assembly.could be a very easy fix.
    Aug 2005
    Phoenix, AZ
    Rep Level
    10
    Rep Power
    Thanks.
    Not really sure exactly what that is but it definitely gives me something to start with.
    Would some Carb cleaner help with that issue?
    RDC's resident crackpot Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon has a reputation beyond repute Ol' Curmudgeon's Avatar
    Dec 2004
    Purgatory, CO
    Rep Level
    5712
    Rep Power
    80
    Carb is probably varnished after 8 months sitting. Rebuild it, paying close attention to settings BEFORE you dismantle it. Carb cleaner may well just move the gunk around, plugging jets and passages. Friends have had good luck w/ Rod's Carburetors near 27th and McDowell, IIRC.
    This may help: http://www.acbs-bslol.com/Gadgets/Zenith.htm
    I used to be an alienated youth, then I became a disgruntled malcontent, next a crackpot, but now I hope to be a curmudgeon.
    Accepted bajaruner11 is just really nice bajaruner11 is just really nice bajaruner11's Avatar
    Apr 2002
    The Deserts bottomless pit, CA
    Rep Level
    149
    Rep Power
    11
    Sounds like your carb is in need of a rebuild, take it to a carb shop or VW engine builder, and have it rebuilt.
    Aug 2005
    Phoenix, AZ
    Rep Level
    10
    Rep Power
    Thanks all. Rod's is really close for me.
+ Reply to Thread
  1. Engine Build Compression Related Questions
    By idealer in forum Shop - Engine
    Last Post: March 6th, 2009, 06:26
  2. Mroe Ford Engine Questions
    By A&A Ford in forum Shop - Engine
    Last Post: July 10th, 2007, 01:53
  3. engine rebuild questions
    By hitman in forum Shop - Engine
    Last Post: June 8th, 2006, 19:20
  4. Engine management system questions
    By Ol' Curmudgeon in forum Shop - Engine
    Last Post: December 6th, 2005, 17:49
  5. Class 9 Engine Questions
    By mike_hinson in forum Class 9
    Last Post: January 22nd, 2002, 12:33
Bookmarks
