Page 2 of 3 First 1 2 3 Last
Results 11 to 20 of 21
Thread: Oxygen sensor
    Forum Junkie FABRICATOR's Avatar
    Ventura County, CA
    Re: Oxygen sensor
    It's hard to say if an OEM sensor would stay hot enough.
    There is something called an "O2 simulator" that eliminates the one in the exhaust and lets you dial in a false A/F input to the ECM.
    Support Our Troops ------ If you can't stand behind them, feel free to walk in front of them.
    If your looking for something blingy and complex, I'm delighted to disappoint you!
    "[Nye Frank] built the best, and never looked to anyone for recognition, the mark of a true man, one of the last true cowboys of our sport!"
    "The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge"
    If you are racing a fair race...your strategy sucks!
    Forum Junkie steveG's Avatar
    Jul 2003
    Arroyo Grande, CA
    Re: Oxygen sensor
    Quote Originally Posted by FABRICATOR View Post
    You think the header won't retain heat like the OE manifold?
    I know a little German... he's sitting over there.
    GoFastBroncos.com
    RDC's illegal immigrant DOG ON's Avatar
    Mar 2006
    Mexico
    Re: Oxygen sensor
    Do you the header being so much cooler?
    All the world’s indeed a stage, And we are merely players
    Performers and portrayers' ....Each another’s audience.....Outside the gilded cage
    Jul 2003
    Arroyo Grande, CA
    Re: Oxygen sensor
    I'm not sure where Chuck was going with that, but it was the only thing I could think of. I really don't see any reason not to use the OE sensor. I don't think the header will have any problem staying hot enough and I don't see why you would want to "fool" the ECM about anything. I'm a fan of just letting things work as intended.
    I would like to hear more about what Chuck meant, though.
    GoFastBroncos.com
    Wham Spore movindirt's Avatar
    Apr 2005
    24.5mi from Timbuctoo, Ca
    Re: Oxygen sensor
    From Advanced Engine Performance Diagnosis, third edition:
    An O2S does not send a voltage signal until its tip reaches a temperature of about 572 deg. F (300 C). Also, O2 sensors provide their fastest response to mixture changes @ about 1472 deg. F (800 C)
    You will see above 600 F @ the header so the O2S should work fine but may be a bit slow. My 2 cents is that a slow reacting O2S is better then a fixed A/F for overall performance.
    Jul 2003
    Arroyo Grande, CA
    Re: Oxygen sensor
    I just consulted one of my techs and he agrees that it would be fine at the collector. There is a chance that the sensor will stop functioning when idling and cruising around at very slow speeds but as soon as you start using the skinny pedal it'll heat up and start working again.
    He sited the old GM 4.3L TBI engines that were actually programmed to go into open loop at idle because the Oxygen senor would drop in temperature. He also said that it took very little for them to start functioning again.
    GoFastBroncos.com
    Ventura County, CA
    Re: Oxygen sensor
    The key word was 'OEM'. If it doesn't keep up he can always upgrade to a heated 02.
    Headers get hot, cast iron gets hot, but what really matters is the EGT. Just changing to a high flow muffler(s) often lowers EGT out of range.
    I'm not suggesting he not use an O2 sensor, he already made that choice. A simulator is closer to using one than what he has now.
    Personally, I would run the O2 and go from there, but people often get upset when I tell them what I would do.
    Prospect B Page's Avatar
    Feb 2009
    Gig Harbor, WA
    Re: Oxygen sensor
    I must agree. Use the O2 sensor. The reason for placing it in the collector, is to have the exhaust gas from all 4 cylinders blasting across the tip of the sensor. This keeps the heat up in the working range.
    Many of the OE O2 sensors are the heated (4 wire) models. They are functional at all RPM, and only take a minute to heat up, from a cold start. They only heat up to the lower functional temp range, so they do have a sluggish response for the ECU, until the RPM brings the EGT up to proper levels.
    No O2 = BAD.
    Fake O2 signal = Limp Home mode
    2 Wire O2 = functioal
    4 wire O2 = more functional
    Regardless of our opinions, the Truth still exists.
    Elite cancinoj's Avatar
    TIJUANA B.C.
    Re: Oxygen sensor
    we recently swap our 4.o ohv to 4.0 sohc for our class 3 ford explorer,. juanco did the ecu tunning and we were having missfiring problems from iddle to 3000, well, after replacing almost everything on the engine,. juanco did a scan to the ecu and it showed some problems with the o2 sensors,. i did the wiring so have to recheck again,. well, it end up to have the left sensor connected to the right sensor and viceversa,. and one sensor was not receiving voltage, we just fix that, and did some test today, and the engine is smoth and strong from idlle to red line,. awsome,. now we are ready for some action this weekend in ojos negros, http://www.essoroffroad.com/ rumors said that roger norman will be driving a class 7s, so, our score class 3 is a class 7s here, ha, so, will see what happens,. see yahh then.
    architectural ilustration artist
    www.cancino3d.blogspot.com
    Senior clogking's Avatar
    Mar 2003
    Solvang , ca
    Re: Oxygen sensor
    Almost all systems go open loop at idle anyways.
    Max Hanberg
    Thinking about the Baja & V2R 24/7
  1. 02 sensor ??
    By cosmo in forum Shop - Engine
    Last Post: August 13th, 2005, 18:46
  2. 02 sensor ??
    By cosmo in forum Whatever - General Discussion
    Last Post: August 8th, 2005, 17:21
  3. temp sensor
    By gary in forum Shop - Miscellaneous
    Last Post: August 28th, 2004, 09:00
  4. Mass Air Sensor?
    By Bajatoy in forum Shop - Miscellaneous
    Last Post: April 30th, 2003, 19:44
  5. HEGO Sensor???
    By shrek in forum Shop - Miscellaneous
    Last Post: December 10th, 2002, 10:31
