+ Reply to Thread
Results 1 to 10 of 17
Thread: front spring hanger problem
    Elite singlehanded is on a distinguished road
    Placentia,Orange County
    Rep Level
    10
    Rep Power
    12
    What would you guys recomend doing, the back hole seems to have worn a little on the bottom?
    I'll post some mote pictures of my project so far........
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69992-MVC-004S.JPG‎ Views:	230 Size:	24.8 KB ID:	2761
  2. Supporter of the Site
    Rep Level
    10
    Rep Power
    12
    Re: front spring hanger problem
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69993-MVC-001S.JPG‎ Views:	189 Size:	31.9 KB ID:	2762
    Rep Level
    10
    Rep Power
    12
    2- body mounts
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69994-MVC-006S.JPG‎ Views:	171 Size:	26.4 KB ID:	2763
    Rep Level
    10
    Rep Power
    12
    3- interior
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69995-MVC-008S.JPG‎ Views:	157 Size:	35.6 KB ID:	2764
    Rep Level
    10
    Rep Power
    12
    4- interior two
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69996-MVC-009S.JPG‎ Views:	138 Size:	43.4 KB ID:	2765
    Rep Level
    10
    Rep Power
    12
    in front of firewall
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69997-MVC-010S.JPG‎ Views:	140 Size:	35.2 KB ID:	2766
    Rep Level
    10
    Rep Power
    12
    6- in front two
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	69998-MVC-011S.JPG‎ Views:	129 Size:	36.7 KB ID:	2767
    Senior In_the_works is on a distinguished road
    Sep 2002
    none
    Rep Level
    10
    Rep Power
    10
    Add some weld where it ovaled, then drill it back to original size, then put a weld on washer on the outside of the hanger with a hole the exact size of the spring bolt. Should be stronger than it was to begin with.
    Rep Level
    10
    Rep Power
    12
    this is just the quality of work that some big shop have. Looks like Im going to weld the rest up myself. funny I dont remember any discount for the 3/4 done welds.....
    Attached Thumbnails Attached Thumbnails Click image for larger version Name:	70003-cage holes.jpg‎ Views:	190 Size:	32.3 KB ID:	2768
    Rep Level
    10
    Rep Power
    12
    That might be good. I was thinking about sanding the sides flat and welding on a 4130 washer from camburg?? I will aslo be adding a tube from the top of the hanger to the frame..
+ Reply to Thread
  1. TH400 Oil leak from front of transmission problem.
    By bert5 in forum Shop - Driveline
    Last Post: May 1st, 2010, 01:46
  2. Spring plate tire problem
    By ElkinsRacing in forum Class 9
    Last Post: December 13th, 2008, 08:52
  3. 1600 Front End Problem
    By Wendell #527 in forum Shop - Suspension & Steering
    Last Post: October 29th, 2007, 20:07
  4. deaver spring hanger location
    By bottlefed98 in forum Shop - Suspension & Steering
    Last Post: May 17th, 2007, 22:27
  5. front spring hangers
    By preronner in forum Shop - Miscellaneous
    Last Post: July 31st, 2004, 22:10
Bookmarks
