November 17th, 2009, 17:18
#1
Need help building equal length beams
I have unequal length beams and want to do a equal length kingpin setup, I dont know if I should use the whole beam or cut and build my own? If any body has any input please!
November 17th, 2009 17:18
# ADS
Join our community today |
November 18th, 2009, 10:39
#2
Re: Need help building equal length beams
I'm making my own equal length beams for a small buggy out of DOM.
I don't know very much about beams myself so I can't give a whole lot of info but I also would be interested to hear what those in the know have to offer.
Hopefully you will get some good responses to this post.
November 18th, 2009, 10:52
#3
Originally Posted by
phantom lighting
on what?coilovers or coil and shock?huge amounts of width or just a little?budget?plans for the truck?a few of the variables that could hinder a good answer for your situation help us out so we can possibly help you.
November 18th, 2009, 17:08
#4
murphco
I will have coil overs and in the future put bypasses on, i plan on racing 1450 then work my way into the 7 class with the same truck. I am on a budget so I thought of buying the kingpin beams or the 4x4 bronco beams? I had unequal with coil overs and they bent so its time for a upgrade in the front end!
November 19th, 2009, 19:10
#5
the king pin beams are pretty good and there already about 6 inches over on a ranger. you will need to cut and turn and bend them however so if you are up to that then go with the king pins. if you check out solo motorsports website and look at the red ranger you can see the beams they fabd up. i am planning on making my own kingpins also just waitin on some money.
November 19th, 2009, 21:16
#6
November 19th, 2009, 22:47
#7
How does one go about making their own custom beams?
November 19th, 2009, 23:38
#8
http://www.race-dezert.com/forum/showthread.php?t=72282
At the bottom of the page. I did a write-up on how I did them.
Turning negative into positive one step at a time...
November 21st, 2009, 21:00
#9
Thank you for that explaination very good! 7/8 or 1 inch king pin? What's the difference in strength for a ranger?
November 21st, 2009, 21:40
#10
7/8"s is plenty strong.
It's just the aftermarket caters to 1" kingpin stuff.
