Results 1 to 5 of 5
Thread: solid tranny mounts w/ solid motor mounts
    Apr 2010
    las vegas
    i am in the process of building a 1450 ranger w a chevy small block and a turbo 400. i have heard and read that if i am doing solid motor mounts i shouldnt use solid tranny mounts. can anyone shed some light on this. im also debating if i should use a motor plate or just the regular type solid motor mounts.
    thanks.
    Elite redline's Avatar
    Oct 2001
    Palm Springs
    Re: solid tranny mounts w/ solid motor mounts
    Solid engine mounts=solid tranny mounts! If you don't do this something will go and it is usually the bellhousing. I learned this the hard and expensive way a long time ago. Mid plates are always a good idea because they help to support the weight of both components.
    Mango Racing
    Twitter @Mango_RacingTT
    Elite Robert Mason's Avatar
    Oct 2003
    Temecula, CA
    I would solid mount the motor, mid plate and rear trans mount.
    Racer matt_helton's Avatar
    Feb 2003
    Yorba Linda, CA
    if you decide to go the motor plate route, we have these to offer.
    http://www.race-dezert.com/forum/sho...ts-Motor-Plate
    Apr 2010
    las vegas
    I have looked at the BMS motor plate before. Nice stuff! Will it work for the mid mount between the trans and block? And what does that require just longer bolts to mate them together?
  1. Solid motor mounts
    By Ziggy in forum Shop - Engine
    Last Post: January 22nd, 2009, 16:09
  2. Solid mounts Versus regular mounts
    Last Post: November 1st, 2008, 08:47
  3. Solid body/cab mounts
    By In_the_works in forum Shop - Miscellaneous
    Last Post: June 16th, 2003, 08:35
  4. need solid motor mounts
    By CaTeRpiLeR in forum Whatever - General Discussion
    Last Post: August 25th, 2002, 22:38
  5. Solid Motor Mounts
    By RHEES in forum Shop - Miscellaneous
    Last Post: August 21st, 2002, 17:10
