+ Reply to Thread
Results 1 to 10 of 17
Thread: 1987 Ford F-150 EFI I-6 problems
    Fresh Blood mcne is on a distinguished road
    Apr 2003
    originally Corona, Ca. now Joplin, MO
    Rep Level
    10
    Rep Power
    9
    I just had a diagnostic done on my engine that has 170,000 miles. When it is cold it had consistant hesitation and was a pain to drive. Once it warmed up it ran o.k. and the hesitation would go away. The diagnostic showed that everything was within specs except: Ignition timing was high as well as emissions. The mechanic recommended new spark plugs. He believed that the ignition timing and high emissions were a result of the engine computer trying to compensate by adding more fuel and timing for poor combustion due to old plugs. I changed my plugs with Autolite platinums. My plug wires and cap and rotor were recently replaced so I left them alone. I also disconnected my battery to reset any codes or calibrations the computer might have had. Now my truck runs much, much worse. It is barely driveable even when warm. There is a huge power loss and surging. The truck will barely make it to 35 mph now. I hear a loud ticking most of the time when I try to acellerate. I have disconnected the computer two more times just in case the memory was not cleared the first time. When I have the engine in park or neutral the engine runs well and will rev to the moon. The ticking sound is either barely there or non-existent. When I put it in drive and try to motor down the road it runs horrible. Why does it run well in park or neutral but not when it has a load on it? I am also wondering about the plug wires arching. I do have the plastic spacers to keep them apart the best I can. Do you think that could be the problem? I ran my code scanner and it shows the same code I had before I changed the plugs. It says my EGO has a constant lean condition. Anyone have any suggestions? Thanks, Brian.
  2. Supporter of the Site
    Racer matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton has a brilliant future matt_helton's Avatar
    Feb 2003
    Yorba Linda, CA
    Rep Level
    2294
    Rep Power
    38
    Re: 1987 Ford F-150 EFI I-6 problems
    did it have platinum plugs before??? if not then go back to a standard autolite plug and then go from there.
    Apr 2003
    Rep Level
    10
    Rep Power
    9
    They are the same plugs.
    Elite Tyson is an unknown quantity at this point Tyson's Avatar
    Dec 2001
    OC, California
    Rep Level
    Rep Power
    12
    Are you sure they are gapped correctly? if so Id also change out your wires to be on the safe side and look at the dist cap make sure it has no cracks.
    T
    Elite tedmales is a name known to all tedmales is a name known to all tedmales is a name known to all tedmales's Avatar
    Jan 2003
    yuma az
    Rep Level
    256
    Rep Power
    13
    the ticking you hear is probably a plug wire arcing. at night start it in a kind of dark area and it will be much easier to see. u can pull each plug wire while the truck is running and see which one does not affect the idle. then when you figure out which one it is check the plugs, its very easy to crack the insulator on the plug.
    Elite tkr has a spectacular aura about tkr's Avatar
    Dec 2001
    Arvada, CO
    Rep Level
    42
    Rep Power
    12
    Sounds like maybe the ticking sounds is a spark plug wire shorting to ground. Give a quick inspection and make sure all the wires are on the plugs and cap tight. If so, have someone sit in the truck with their foot on the brake and rev the enging a little in drive. While they're doing that grab a water spary bottle, spary the wires and watch for sparks.
    Senior 1992f150 is on a distinguished road
    Dec 2001
    Azusa, Shame of the foothills
    Rep Level
    10
    Rep Power
    11
    if you pull the spark plug wires off while its running, be sure you are wearing rubber gloves and dont lean on the fender/firewall/any grounded part.
    Senior curt will become famous soon enough curt's Avatar
    Dec 2002
    Santa Clara, CA
    Rep Level
    29
    Rep Power
    10
    Try the start it in the dark thing first, some computers may give you problems with the old unplug the wire while running trick. Also they make cheap wire pulling pliers with about a 1/2" circular cutout that fits over the boot and has rubber in it to keep from damaging the wires. When you pull the right wire, the motor soqnd won't change...Curt
    RDC Addicted Jack is a splendid one to behold Jack is a splendid one to behold Jack is a splendid one to behold Jack is a splendid one to behold Jack is a splendid one to behold Jack is a splendid one to behold
    CA
    Rep Level
    699
    Rep Power
    20
    You will need help with the dark test, you need to put a load on the motor, as you said it runs fine in nutral. Have someone put it in gear with foot on the brake then a little gas to simulate driving condition. Then look for "the dancing angles" it must be very dark no street lights or keep the hood down some to block the light. My guess is that pulling the plug wires they got pulled apart at the boot. Also there may be a problem inside a plug, The only way I know to check this is to use an engine scan (not sure what it is called, but it has a screen and will look like a hart rate monitor) to see the resistance at each plug fireing and will tell you wich one is the problem.
    Apr 2003
    Rep Level
    10
    Rep Power
    9
    Replying to all- Thanks guys. I am going to try everything tonight. Someone asked if my plugs are gapped correctly. YES. I also have spark plug wire plyers so those should help keep me from getting toasted. I have never heard of the water bottle trick. Does that make the archs more visible? I appreciate everyone's help. Hopefully I will find and fix the problem. I will let you know how it turns out tonight or tomorrow. Brian.
+ Reply to Thread
  1. Newbie with 1987 Ranger Needs Guidance
    By Alladinzane in forum Hello, My name is _______
    Last Post: March 1st, 2009, 22:43
  2. My 6th Mint 400 (1987)
    By Old School 8 in forum Desert Racing
    Last Post: July 15th, 2007, 21:37
  3. 1987 F-150 Speedometer recalibration
    By mcne in forum Shop - Miscellaneous
    Last Post: June 15th, 2004, 10:03
  4. 1987 F-150 problems Part 2
    Last Post: February 21st, 2004, 16:26
  5. 1987 ranger rearend
    By boltonbros in forum Shop - Miscellaneous
    Last Post: February 20th, 2003, 14:27
Bookmarks
