+ Reply to Thread
Results 1 to 10 of 19
Thread: HELP! New brake system and no brake pressure???
    Spam Whore atomicjoe23 is a splendid one to behold atomicjoe23 is a splendid one to behold atomicjoe23 is a splendid one to behold atomicjoe23 is a splendid one to behold atomicjoe23 is a splendid one to behold
    Silverdale, WA
    Rep Level
    490
    Rep Power
    15
    I installed a whole new brake system (front-to-rear. . .new lines, calipers, master cylinder, proportioning valve, everything) and I've pumped fluid through the system going through the bleeder valves to the M/C and I still don't have any pressure in the system when I pump the brake pedal???
    I have no idea why this could be???
    Could anybody PLEASE help me out? BTW, this is the first time I've done this, but it seems like to me if you've verified that the lines are full of fluid, there are no leaks and the fluid can make it from the calipers to the M/C that you should be able to get some pressure in the system. . .but that's just me.
    Thanks for the help!
  2. Supporter of the Site
    Silverdale, WA
    Rep Level
    490
    Rep Power
    15
    Re: HELP! New brake system and no brake pressure???
    No suggestions???
    I could really use some help here. . .I'm out of ideas.
    Thanks!
    Ironman Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani has a reputation beyond repute Ramsey_ElWardani's Avatar
    Carlsbad, CA
    Rep Level
    8840
    Rep Power
    107
    Try bench priming the Master Cylinder
    Ramsey El Wardani
    Smarter Than Dirt!
    One Man Racing
    Bear on a Unicycle Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon's Avatar
    Campo,Ca
    Rep Level
    4174
    Rep Power
    48
    Quote Originally Posted by atomicjoe23 View Post
    Had this same problem, primed master cylinders, then borrowed one of those brake system primers,still problems we ended up making a fitting to put in the master cylinder res filled full of brake fluid pushed a small amount air bleed a little added fluid ect until we got all the air out!!! everyone told us it should be easy but it wasn't. BTW if you have leaks it will screw you up!!!
    If you think can or can't,your right!!!!
    Silverdale, WA
    Rep Level
    490
    Rep Power
    15
    Thanks Shannon. . .I think I got all my leaks tightened up.
    I'll have to just keep on trying.
    Forum Junkie steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG is a splendid one to behold steveG's Avatar
    Jul 2003
    Arroyo Grande, CA
    Rep Level
    710
    Rep Power
    19
    No suggestions???
    Thanks!
    Sheesh, give us more than an hour and 11 minutes to answer!
    Make sure your calipers are on the correct sides. If the bleeder is on the bottom you'll never get the air out.
    I know a little German... he's sitting over there.
    GoFastBroncos.com
    Elite glamiskid395 is a jewel in the rough glamiskid395's Avatar
    Apr 2008
    Moreno Valley, CA
    Rep Level
    82
    Rep Power
    I'm kinda having the same problem with mine, no leaks, no bubbles, but still not a lot of pressure, even when pumped a few times. I had g&j plumb it and they put 2 psi valves on (I can't think of the name, brain fart). Well I had a few guys tell me I needed 10 psi so I put those on and bled it, that help a little, but still not the beat.
    Sorry for the thread hi-Jack
    1420 Fox Racing!
    KING shocks, CBR, SLIME, General Tire, B&K, Rainbow Bolt, Cal-Mesa Steel
    Silverdale, WA
    Rep Level
    490
    Rep Power
    15
    Quote Originally Posted by steveG View Post
    I was just hoping I'd get the ball rolling. . .sometimes I can post up on here and I'll have a reply that answers my question in less than 15 minutes which is awesome!. . .but it's summertime right now and I know most people are outside doing stuff instead of sitting inside at their computer.
    I made sure of that when I installed them. . .bleeder valves on top.
    Quote Originally Posted by glamiskid395 View Post
    Those are residual pressure valves. . .they are only needed if your M/C is below the level of your calipers. They are supposed to keep the brake fluid from gravity draining back to the M/C. . .
    . . .also the 2 psi valves are for disc brakes and the 10 psi valves are for drum brakes. . .so if you have disc's then you have the right RPV's.
    Apr 2008
    Moreno Valley, CA
    Rep Level
    82
    Rep Power
    Thanks, will the 10psi hurt the calipers at all? I don't feel like changing them out and bleeding them again tomorrow in Barstow, when I had the 2psi, I could not get any pedal pressure. With the 10psi, it's alot better.
    1420 Fox Racing!
    Rookie 3times will become famous soon enough
    Apr 2009
    Simi Valley, CA
    Rep Level
    15
    Rep Power
    Do this
    1) fill resi full LEAVE THE CAP OFF
    2) Open BOTH Rear bleeders let flow until good amount of fluid comes out
    3) Close rear bleeders
    4) Open front bleeders both at same time just like the rears when significant(Puddle) of fluid has come out of both close
    5) Bleed brakes normally (pump gently and hold) starting with wheel farthest from maste cylinder
+ Reply to Thread
  1. Best way to fill & bleed a brake system from completely empty???
    By atomicjoe23 in forum Shop - Miscellaneous
    Last Post: August 30th, 2010, 22:12
  2. Wiring brake lights from hydraulic brake switch???
    By atomicjoe23 in forum Shop - Electrical
    Last Post: July 16th, 2010, 09:56
  3. Tyre Pressure Monitoring System
    By redmist in forum Shop - Driveline
    Last Post: October 1st, 2009, 10:24
  4. brake pressure residual valve
    By Ryan B in forum Shop - Driveline
    Last Post: October 5th, 2008, 23:34
  5. Brake caliper placement versus brake torque effect
    By Scott_F in forum Shop - Suspension & Steering
    Last Post: March 24th, 2006, 16:04
Bookmarks
