+ Reply to Thread
Results 1 to 6 of 6
Thread: 4.0 electric fuel pump???
    Prospect Brazzo is on a distinguished road Brazzo's Avatar
    Apr 2005
    Yuma, Az
    Rep Level
    10
    Rep Power
    can you guys recommend a good external inline electric fuel pump for a 4.0 Ranger, the engine is stock and I'm installing a fuel cell, any advise on a pump? brand? maybe even a part number? anything helps, Thanks.
    ~~~~~~~~~~~O^o>
    If you are going to be dumb,
    YOU BETTER BE TOUGH!!!!!
  2. Supporter of the Site
    Fresh Blood ruff ranger is on a distinguished road ruff ranger's Avatar
    Beaumont,C.A.
    Rep Level
    10
    Rep Power
    Re: 4.0 electric fuel pump???
    there are lots of good ones like aeromotive a1000. just make sure you know if its a puller or pusher pump. some pumps like to be mounted near the cell and some near the engine. I have run the aeromotive on my ranger for the last 8 years with zero issues.
    Mini Metal MOD DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing has a reputation beyond repute DSRacing's Avatar
    Jan 2003
    San Diego
    Rep Level
    2637
    Rep Power
    42
    Some good (and bad) info on fuel pumps in this thread,
    http://www.race-dezert.com/forum/sho...that-dont-suck
    Caution! Tony T. said I could be dangerous.
    One man's fun is another's hell.
    RDC Addicted charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown has much to be proud of charlie_brown's Avatar
    Oct 2002
    Yorba Linda Ca
    Rep Level
    910
    Rep Power
    21
    why not use the stock one. you can get them anywhere.
    my last motor i used the stock one (it had 2) and on my new motor, i am going to use the stock one also.
    chris(charlie brown) goes to baja
    Bear on a Unicycle Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon has a reputation beyond repute Shannon's Avatar
    Campo,Ca
    Rep Level
    4174
    Rep Power
    48
    I'm a freak about this due to the fact that I lost a race because a fuel pump issue , first off as a pump man I understand, it takes almost twice the amount of energy to suck fuel from the tank as it does to push into the system so with external pump you are at a disadvantage, so I was way overkill with ours . the primary pumps-2 were mounted inside the tank, never had a problem, we secured them right, second we had a bronco 2 external pump mounted where easy to get to with a second bronco two pump mounted on hose clamps ready to trade out if needed, yes over kill I know but we never had fuel problems again, and never needed to even use the external pumps, internal are the way to go IMO.
    If you think can or can't,your right!!!!
    Apr 2005
    Yuma, Az
    Rep Level
    10
    Rep Power
    thanks for the ideas guys.
    ~~~~~~~~~~~O^o>
+ Reply to Thread
  1. Electric water pump
    By HardCharger81 in forum Shop - Engine
    Last Post: May 22nd, 2010, 15:58
  2. Cherokee Electric Fuel Pump
    By Schlingmann in forum Shop - Miscellaneous
    Last Post: August 4th, 2009, 10:00
  3. Dual In-Line Electric Fuel Pump Recommendations?
    By ScottWisdom in forum Shop - Engine
    Last Post: February 18th, 2006, 20:50
  4. Electric Fuel Pump
    By class7s in forum Shop - Engine
    Last Post: March 26th, 2005, 09:41
  5. Electric Fuel Pump
    By mike_hinson in forum Class 9
    Last Post: October 13th, 2003, 10:47
Bookmarks
