thanks Parker Motor Co, for the good deal! yes we got it, and looks like my boss love it, now starting to put some equipment to be ready to chase the Baja 500.
PD question, Jerry@camburg, if we put those upper arms, does void the factory warranty?
maybe Jim (PMC) can chime in !
Onwards Ever, Backwards Never....If In Doubt...... Flat Out.
NTR Films/La Granja Escuderia/Mango Racing/Impact by Mastercraft Safety/Wero's Body Shop.
Congrats! Ill ask the service guy at PMC real fast..
Ok, heres what i got "If it has a suspension issue that is caused by that then yes it will...if there is type of damaged that can be assumed is caused by that they would view it as a modification and void it" -service guy at PMC.. lol but drive train minus maybe a front cv or axle would still be fully covered.
For the most part in 15 years as Camburg we have never had warranty issues or customers with issues.
This is how it works. If you install aftermarket shocks/coilovers the OE will not cover those parts. If you install upper arms the OE will not cover the upper arms. Front shocks and upper arms have nothing to do with the engine so there would be no void in the engine or trans caused by front suspension.
Now if you have a drop down bracket suspension on a 4x4 truck there MIGHT be an issue if the front diff/axles started having issues. But when you look on Ford show room floors there are tons of brand new lifted trucks going out the door every day.
It really comes down to this. If you modify the suspension those modified components might be voided from warranty. If you add a chip or super charger the engine/drive train might get voided.
We have known of multiple customers having warranty work done to trucks with full blow LT kits and have not had any customers not have warranty things handled because of suspension mods.
Adding upper arms has nothing to do with the engine or drive train. Now adding an under slung Deaver race spring pack and 18" by-pass shocks threw the bed might/probably will void the driveshaft from warranty if the drive shaft was to have issues.
It is best to check with the service manager at the dealership and ask them what will be covered and what won’t be.
