If laughter is the best medicine, I am part of its corrupt pharmaceutical lobby![]()
UNDERGROUND R.A.DESIGNS ORANGE ARMY SOLDIER LEMONS RACER CAMBURG FAST-aid WTAR
Two thumbs up!....I dig that bag and like the idea that it could be hung from a couple of hooks when needed...Husky makes a cool bag that organizes tools pretty well for the field. I've had it for a while and it rocks.
I also lash everything down tight.....Have a rack system that allows for basically unlimited set-ups...
They are....I can show you some pics if that helps to get your creative juices flowing...Lou i am gonna bug you on TT about how you did some of those, that look like modded utiitrack hooks?![]()
I take the Titan stops that come with the cleats, remove the 10mm hex head bolt. I drill and tap the steel base for 7/16"-20....The same thread used for the hi-strength eye bolts used for seat belts...and finally drill out the aluminum stop block 7/16"...I now have a very strong eye bolt that can be moved anywhere along the tracks...I pick up the eye bolts from a seat belt supplier...
I can also use them to both hold something to the bed and still have the eye bolt to use as you can see in the pic where I attached my aluminum gas can holder to the floor and bed side...
You can remove the actual cleat from the base and have a moveable lock down base but mine now have 2 eye bolts to allow the use of turnbuckles to firmly hold down my tool box & ice chest...This has worked great for several years now including a couple of Baja Chase runs...
Im looking for a that's similar to this only I need to carry more tools like crescent wrench's, plyers, vise grip's etc. etc. I'm so tired of carrying 2 bags of tools around with me.
Same bag?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I have all my stock cleats if you want them. I was going to sell them but I'd rather you use them if needed
I'll keep my Guns, Freedom & Money, YOU can keep the "change".
