    Dismiss Notice
2500HD Chase truck Long Travel susp
Discussion in 'Shop - Suspension & Steering' started by TimG_AZ, Sep 24, 2006.
  1. TimG_AZ
    TimG_AZ Well-Known Member
    Jun 12, 2005
    Scottsdale, AZ
    I need to build a chase truck on a 2500HD Duramax/allison. I looked in the business directory and found fabtech makes a long travel kit for this truck.
    does anyone else have a long travel kit for the chevy 2500HD ?
    also to put 35 BFG KR's on it will it also need to be lifted or just glass fenders with the LT kit?
    thanks for the help.
    Tim
  2. Brandon_Charley
    Brandon_Charley Formerly "Cracka Racing"
    Apr 12, 2005
    Huntington Beach, California
    Fabtech doesn't make real long travel kits, they just call them that, they're really just lift kits so if you really need long travel you are going to need something custom.
  3. Ryno
    Ryno Well-Known Member
    Sep 24, 2001
    Yucaipa, CA
    Everything right now is a lift kit. CST, Fabtech, etc. To run's 35's...you gotta lift it. You can run a 33" tire stock. I put Bilsteins on mine, and it rides 200% better. I haven't seen an HD with glass on it.
  4. 1450-ranger
    1450-ranger Well-Known Member
    Jun 13, 2004
    CA
    Look into Blitzrkrieg as they make steering kits for the HD's. Nice work
    www.bmsoffroad.com
  5. deleted
    deleted ----
    Apr 1, 2001
    I have a CST on mine... I will sell it.
  6. John_Bitting
    John_Bitting Administrator
    Apr 10, 2001
    Rancho Santa Margarita
    The fabtech kit looked nice at SEMA last year but I heard was having some problems blowing out balljoints and then uniballs.
  7. TimG_AZ
    Jun 12, 2005
    Scottsdale, AZ
    Thanks for all the help guys. Really appreciate it. Found a Camburg LT kit. May end up just lifting like you guys are saying. thanks again, tim
  8. Brutpwr
    Brutpwr Well-Known Member
    Dec 23, 2005
    San Jose, Ca
    Don't know anything about the steering kit mentioned earlier but I would look into it as these trucks do have steering problems especially when lifted and running larger tires.
    Jason :)
  9. CMazzulla
    CMazzulla Well-Known Member
    Aug 16, 2005
    Highland , CA
    I know a guy that can sell you a long travel kit, pm me for the phone number
  10. PBR
    PBR Well-Known Member
    Apr 6, 2001
    Culver City, CA
    brian kudela's company www.lightracing.com does hd's for the military and he makes really trick stuff.
    don't put a "lift kit" on it if you want to chase with it, you will kill the steering and ball joints.
  11. Benny Metcalf
    Benny Metcalf Well-Known Member
    Dec 10, 2004
    Lake Forest CA
    Good point Ollie, Maybe just a little bigger tire on it....
  12. johnnyweb
    johnnyweb Well-Known Member
    Jan 24, 2003
    Gilroy-Shop
    i would stick to stock suspension, little larger good a/t tires,maybe some nice shocks. possibly a winch and some nice lights to help in a extraction situation. set up the bed to hold your tires, tools, supplies, etc. also a way to lock your tools up when they are in the bed and spend your $ on race car parts, spares etc. the long travel lift will do nothing for your cargo load carring and trailer hauling capability. which is the primary job of your chase truck. just my opinion!!
  13. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    Hahahaha, Sorta like that kid that tried to go through Simpsons last year and blew both BJ's within 100 yards of each other. Those guys were out there for a very long time.
  14. Chase 2
    Chase 2 Well-Known Member
    Jan 8, 2005
    Simi Valley, CA
    Save the lifting and fancey suspension for pre-runners and two wheel drive freeway play toys. Keep the 4X4 chase truck as a work horse you can depend on.
  15. PBR
    Apr 6, 2001
    Culver City, CA
    i would recommend the torsion keys, fox make a shock just for the front of the hd's with the torsion key lift (i think bitting has them on his rig) and some 285's on the stock wheels. some heavy duty tie rod sleeves and you will be dialed in.
  16. baja619
    baja619 Well-Known Member
    Aug 7, 2004
    Corona / San Diego
    This would be the best option by far. Check out the site for a video hitting a "whoop style test section" with the light bump stops. the vehicle was able to travel something like 20% faster in complete control.
  17. Kritter
    Kritter Krittro Campbell
    Jun 18, 2001
    No issues...even at 40mph thru start finish several times, although I cant say the truck as a whole held up! The only way they could have pushed the truck harder would have been if it was caged.
Verification:
Draft saved Draft deleted
Share This Page
