    Dismiss Notice
930 cv have a direction ?
Discussion in 'Shop - Driveline' started by eilatmar, Apr 3, 2009.
  1. eilatmar
    eilatmar Member
    Nov 9, 2006
    eilat israel
    hi frinds
    iam going to use 930 cv`s on my buggy but not sure if its have a side that go into the flang and a side that gos to the axle.
    thanks
    hanan
  2. punchdrunk monkey
    punchdrunk monkey Well-Known Member
    Apr 5, 2006
    Poway, CA
    Here's a good picture for you.
    [​IMG]
  3. punchdrunk monkey
    Apr 5, 2006
    Poway, CA
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    (+1) 1 person likes this.
  4. Tipracer
    Tipracer Well-Known Member
    Sep 6, 2005
    So. CA
    while it is not as important to use the cv's in the same position as they came out as in direction of rotation, it is very important that the axels be used in the same direction of rotation ...you can use the left side on the right side ONLY if you swap the inside end of the axel to the outside end when going from right side to left side
  5. Ramsey_ElWardani
    Ramsey_ElWardani Ironman
    Apr 1, 2001
    Great posts and pictures. I have been using the same methods for years with perect redults. Though I position the cage as you do, it is interesting to note that Fortin suggests the opposite; small dia. inside. I've found it does not seem to matter. This was from an old thread:
  6. 07FJRog
    07FJRog Well-Known Member
    Feb 26, 2009
    Tonopah, AZ
    great pics for assembly, thanks
    +rep
    Rog
  7. Kbach66
    Kbach66 Well-Known Member
    May 9, 2002
    Simi Valley, CA
  8. eilatmar
    eilatmar Member
    Nov 9, 2006
    eilat israel
    dear frinds
    thank you very very much.
    this is my project.
    hanan
    [​IMG]
Verification:
Draft saved Draft deleted
Share This Page
