    Dismiss Notice
Bending 1'' tube with a 1 3/4" Die
Discussion in 'Shop - Fabrication' started by MX808, Sep 8, 2009.
  1. MX808
    MX808 Well-Known Member
    Dec 8, 2003
    Las Vegas, NV
    Is it possible to do without squishing the tube?
  2. Chase 2
    Chase 2 Well-Known Member
    Jan 8, 2005
    Simi Valley, CA
    Test to see if you can get away with the tube filled with sand before bending You may or may not get away with it.
  3. ZTFab
    ZTFab Well-Known Member
    Dec 6, 2004
    San Dimas, CA
  4. MX808
    Dec 8, 2003
    Las Vegas, NV
    Thats what i was thinking because i have bent square tubing like that before.
  5. Baileigh Inc
    Baileigh Inc Well-Known Member
    Sep 9, 2009
    Manitowic, WI
    I have heard mixed results from this
  6. Triaged
    Triaged Well-Known Member
    Nov 25, 2003
    SoCal LA/OC border
    Because sand got brought up you might want to take a look at this.
  7. Brock_Beeson
    Brock_Beeson Well-Known Member
    Feb 18, 2005
    vista, ca
    i would never recommend this on anything that might save/ risk your life.
  8. Baileigh Inc
    Sep 9, 2009
    Manitowic, WI
    Sand bending tube looks like a ton of monkey-ing around.
  9. Triaged
    Nov 25, 2003
    SoCal LA/OC border
    But you would trust your life to a 1" tube bent in a 1.75" die? Obviously not. But if you are going to pack it in sand using the technique in that article might help you out (namely using washed sand and a soft wood slapper). It might also help you bend thin wall 1.75" tubing in your thick wall 1.75" die to do exhaust work.
  10. kibbetech
    kibbetech Well-Known Member
    May 18, 2009
    thousand oaks ca
  11. etl450
    etl450 Well-Known Member
    Sep 1, 2009
    Oklahoma
    This is how tube was bent before they created mandrel benders. They also use this method in water jacketed exhausts.
  12. MX808
    Dec 8, 2003
    Las Vegas, NV
    I would do that if i would use it more than twice. All i need for is to make 2 bends to make a new light bar for my car. It just didnt seem cost effective to buy a die thats only going to be used twice. I have started the light bar and will post some pics after i make the bends.
  13. Baileigh Inc
    Sep 9, 2009
    Manitowic, WI
    :cool:
    :cool: Keep us posted. I'm interested to see what will happen
  14. Chase 2
    Jan 8, 2005
    Simi Valley, CA
    So, how did it come out???
  15. FABRICATOR
    FABRICATOR Well-Known Member
    Apr 3, 2001
    Ventura County, CA
    Been there done that, sand bending sucks.
  16. MX808
    Dec 8, 2003
    Las Vegas, NV
    Came out really well i will get some pics of it tonight and get them up asap.
  17. wrightracing.net
    wrightracing.net Well-Known Member
    Oct 16, 2005
    I hope it works for you but in the past I had it flatten out a bit but I did not use sand. I just cot a die for my model 4 bender for $200 and it is just one of those sizes you should have. Sizes to have are 1", 1.25", 1.5", 1.75" and 2". I just need to get a 1.25" die and I will have a full set, then I am thinking of picking up some square tube dies.
  18. RoosterBooster
    RoosterBooster Well-Known Member
    Feb 3, 2008
    AZ
    bringing back this older thread to add a "trick" that was not mentioned ;)
    some time ago i needed to make some clean 1.25 bends in a hurry but i had only a 1.5 and 1.75 die.... so i bended a scrap section of 1.5 x .120 DOM , removed the bended tube , split it in half with the plasma, cleaned it up, and bingo; i got myself a dirt cheap 1.25 bender insert :p .... works perfect for that dimensions that i dont use very often ;)
  19. MX808
    Dec 8, 2003
    Las Vegas, NV
    Hey thanks for bringing this back up i had pictures but couldnt find the thread. I will have to go out in my shop tomarrow and get some new ones with the lights mounted on it.
  20. ZTFab
    Dec 6, 2004
    San Dimas, CA
    I mentioned that in this thread....which I posted the link to on the first page. ;)
    Here is my post from the other thread:
    That trick works great. I learned it from Dave Turner.
Verification:
Draft saved Draft deleted
Share This Page
