    Dismiss Notice
BFG tire weights
Discussion in 'Shop - Miscellaneous' started by Scott_F, May 27, 2004.
  1. Scott_F
    Scott_F Well-Known Member
    Dec 28, 2003
    Tucson, was Anaheim
    I have been researching BFG tire weights for sizes over 34". See the attached file for a cleaner version.
    Tire Size MSPN Rim Width Width Dia Max Load Weight
    BFG Baja T/A 3 ply, 2 steel belts 2 nylon belts
    35x12.50R15/C 02516 8.5 - 11.0 12.8 on 10.0 34.8 2555@35 63.59
    LT315/75R16/C 45852 ^ 8.0 - 10.0 12.8 on 8.5 34.6 2535@35 64.65
    35x12.50R17/C 49244 ^ 8.5 - 11.0 13.2 on 10.0 34.6 2400@35 65.58
    37x12.50R17/D 89885 ^† 8.5 - 11.0 13.4 on 10.0 36.7 3480@50 75.32
    ^ These sizes utilize the solid center rib tread design proven in desert racing ("project" tread).
    †This size uses 4 full nylon carcass plies.
    BFG AT T/A 3 ply, 2 steel belts
    35x12.50R15/C 95210 8.5 - 11.0 12.7 on 10.0 34.7 2555@35 53.54
    LT315/75R16/D 95328 8.0 - 10.0 12.1 on 8.5 34.7 3195@50 62.12
    LT315/70R17/D 54142 * 8.5 - 10.0 12.0 on 8.5 34.5 3195@50 64.65
    37x12.50R17/D 99249 8.5 - 11.0 12.8 on 10.0 36.3 3525@50 65.71
    LT325/60R20/D 41857 9.0 - 12.0 13.0 on 9.5 35.5 3195@50 66.99
    37x12.50R20/D 74497 8.5 - 11.0 12.5 on 10.0 36.6 3085@50 68.53
    2QStock
    * Size does not meet the RMA requirements for severe snow conditions.
    BFG Krawler T/A 4 ply, 2 steel belts
    35x13.50R15/C 44690 8.5 - 11.0 13.8 on 10.0 35.0 2600@35 78.96
    37x12.50R17/C 73977 † 8.5 - 11.0 12.9 on 10.0 37.0 2755@35 84.47
    37x12.50R17/C 51716 8.5 - 11.0 12.9 on 10.0 37.0 2755@35 84.01
    †MSPN# 73977 features a partially blank tread, and is intended for custom-grooving and tuning by the user.
    All Krawler T/A®KX tires are L-speed rated. Do not use at speeds in excess of 75mph.
    BFG Adventure Assurance Program for All-Terrain T/A KO and Mud-Terrain KM tires. 877 788 8899
    The BFGoodrich Tires Adventure Assurance Program applies only to tires purchased within the United States and is available 24 hours a day, 365 days a year, anywhere in the United States and Canada for 24 months from the date of purchase. To receive roadside assistance you must call the toll-free number located on the Adventure Assurance card received at the time of purchase. A service provider will be dispatched to your location. In the event of a flat tire, the service provider will replace the tire with your inflated spare. Service will also include off-road towing for BFGoodrich tire customers whose vehicles are stranded in difficult terrain such as mud, snow, sand, or ice. With a couple of decades of experience supplying premier off-road tires to extreme enthusiasts, we know we have to look out for the service providers too, so service will depend solely upon safe tow truck access to the scene as determined by the service provider.
    The service professional will ask to see the card provided with purchase. If you need a replacement card, please contact the place of your tire purchase. This service is not transferable and is only for the vehicles for which the tires were purchased. Service is provided on a sign-and-drive basis. There is no out-of-pocket cost for the covered service, up to the maximum benefit allowed. You simply sign the receipt and drive away. If the cost of service exceeds the amount allowed, you will be responsible to pay the difference at the time service is rendered. Services are limited to a maximum of $60.00 per incident and three incidents per year per customer.
  2. Scott_F
    Dec 28, 2003
    Tucson, was Anaheim
    Here are some 33's
    33x 9.50R15/C 95155 6.5 - 8.5 9.5 on 7.5 32.7 2510@50 40.11
    33x10.50R15/C 75595 7.0 - 9.0 10.6 on 8.5 32.7 2620@50 44.67
    33x12.50R15/C 75406 8.5 - 11.0 12.4 on 10.0 32.7 2225@35 49.30
  3. gosouth
    gosouth Well-Known Member
    Sep 24, 2003
    Brawley
    If anyone happens to have the weights of the Goodyear offroad tires that are commonly used it would make a nice comparison.
    GOSOUTH
Verification:
Draft saved Draft deleted
Share This Page
