    Dismiss Notice
chassis jig
Discussion in 'Shop - Miscellaneous' started by Ryan B, Jan 27, 2004.
  1. Ryan B
    Ryan B Well-Known Member
    Jun 11, 2003
    sparks nv.
    My boss and I are going to build a jig for a manx we have in the shop. Does anyone know were I can find some good pictures of any chassis jigs.
    thanks
  2. ntsqd
    ntsqd Well-Known Member
    Sep 17, 2001
    Here
    There are purpose built chassis plates, but a jig is pretty much what you want/need it to be. Commonly a Dragster jig is based on a Large I or W beam.
    For those road racing cars that we needed to jig we used a big steel cart that weighed about 500lbs by itself. We'd lower the car onto jackstands on the cart with the car hoist. Then any hard points (Suspension pivot points, engine mounting tabs, etc.) that were not being cut out got tabs bolted to them. The tabs where then welded to stand-offs which where tack welded to the cart. All of the stand-offs were then braced. None of this was pretty, just functional.
    Once we had all of the tabs deemed needed picked up, we would remove the jackstands and go about what ever mod was to be made.
    If you are going to be doing more than one, then designing the stand-offs to be easily removed would be worthwhile. Everything I did was one-off so they were usually sawzalled off the cart and the cart's deck was ground flat.
  3. UndercoverFab
    UndercoverFab Well-Known Member
    May 16, 2003
    the wrong side of the country
    my jig is more like a table, 4x6 one inch plate with 3 slots per side that sliding mounts can go in that`ll lock in to hold tubing in place, it sits on 2x2 square tubing with some beefy casters mounted on jack screws, i can raise or lower the table 20 inchs and also use them to level the table on any surface. I`m real happy with this setup for what i do with it, the only thing i might change is rig up some sort of drive to turn the jackscrews instead of having to do it manually.
  4. SpareChangeRacng
    SpareChangeRacng Well-Known Member
    Nov 30, 2001
    Balboa Island
    Here's ours (Rob's actually) with my truck, or what we cut it down to, welded to it. It's square, and if we took the time to mount the pads we made for it could be level too.
Verification:
Draft saved Draft deleted
Share This Page
