    Dismiss Notice
chevy 2500HD long travel?
Discussion in 'Shop - Suspension & Steering' started by bean dip, Feb 24, 2008.
  1. bean dip
    bean dip Well-Known Member
    Feb 1, 2008
    HEMET CA.
    doe's anybody make a long travel kit for the 2500HD chevy, if so is it any good. im thinking of running 37' tires and want LT kit for chase truck.:D
  2. jeff
    jeff Moderator
    Apr 1, 2001
    California
    Chase truck... hmm... 2wd or 4wd? If you want to built a 4wd truck the front diff, axle shafts, hubs, are all going to need to be replaced (expensive) if you want a reliable long travel 2500HD running 37's. If you are willing to drive a timebomb you can run the factory stuff. Unless you've got mega bucks to build it right you might consider ditching the IFS and running a solid axle. You can get decent travel and reliability from a solid axle for far less than a full custom IFS system.
    Or...
    http://www.fabtechmotorsports.com/applications/gm/4wd01-06-gmk2500hd.html
    Aloha
  3. xnoregretsx
    xnoregretsx Well-Known Member
    Feb 19, 2007
    559
    isnt 2wd 2500 front end the same as the 1500?
    i cant imagine it being any different you dont tow with yoru front a arms and stuff...
    i know the rearend has a bigger rearend and all that mess but up front im thinkin its the same.. if ur only chasing u shoudlnt need a all out race kit.. a decent spindle lift and a smaller bypass and air bumps ..
  4. Ryno
    Ryno Well-Known Member
    Sep 24, 2001
    Yucaipa, CA
    Not to contradict jeff...but I was told the PRO4 CORR guys all run a 2500hd front driveline. Granted, they change it out every round, but you can get the parts for decently cheap. A complete front axle shaft runs$100. I saw the fabtach kit, and it's REALLY nice. I put bilstein 5100's on mine, and 285 tires.
    The other thing is steering. If you run anything over the factory pizza cutter tires, you have to upgrade it. I got the Cognito kit, and it does okay. I don't use mine for full chase duties, but it's the rescue and retrieval truck for our group in the desert.
  5. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    If you want something beatable, your only choice is goingto be custom. Like this http://jdfabrication.com/photos/SS/index.html
    The outer CV's are plenty strong enough, the inners need replacing. So far now problem with the 934's.
    After you fix the steering, the frame will start to flex. They are now fixing another Cheby buy cutting off the front of the frame.........
  6. bean dip
    Feb 1, 2008
    HEMET CA.
    2WD, Im going to chase and run around the desert.
  7. Lance
    Lance Well-Known Member
    Jan 22, 2008
    Marysville Wa.
    Ill build you one Pm me and ill send you some pics of stuff i have built
  8. Desertbound
    Desertbound Active Member
    Apr 12, 2005
    San Luis Obispo, Ca
    Does anyone know what JD fab did for axles on that 4wd kit? Are they custom, lengthened stockers or what?
  9. rlury
    rlury Well-Known Member
    Dec 3, 2007
    Santa Fe New Mexico
    check out muzilla they have some pretty sweet long travel kits for the hds.
  10. CODY_BUH
    CODY_BUH New Member
    Nov 7, 2007
    Riverside, CA
    i know mazzulla did an 2500 kit a while back...he'd have to do it custom though..but hit me up..
  11. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    Custom lengthened axles with stock outer CV and a 934 inner. The original set had 930 inners, but they only lasted a couple of trips. So far now problems at all with the 934's. They had the inner adapter plates machined locally and the axles were Swayaway or TCS, I can't remeber.......
  12. jesusgatos
    jesusgatos Well-Known Member
    Feb 11, 2004
    on the road
    That's the conclusion that we came to. It's still not done though, and has been at Troy Johnson's shop for longer than I'd like to admit. Here's a link to some of the updates through the build-up.
    [​IMG]
    [​IMG]
  13. gawdodirt
    gawdodirt Well-Known Member
    May 22, 2003
    Gilbert, AZ
    Light racing has a kit for this and it's pretty bulletproof. It's the one chosen by the Border patrol with bumpstops. Very good stuff and great off-roadability. But it's not too lifted. 35' for sure, 37's maybe.
    If you're after the performance go with Light Racing. If your after a "look" anything else will do.
    GD
  14. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    Linky no worky....
  15. jesusgatos
    Feb 11, 2004
    on the road
    Really? It seems to be working for me. Try again?
  16. crazyjohnny
    crazyjohnny Well-Known Member
    Jul 24, 2006
    Oxnard/Chico, Ca
  17. CMazzulla
    CMazzulla Well-Known Member
    Aug 16, 2005
    Highland , CA
    I have built an Hd before also and I will say that you are better off going with a cst kit (dropdown 4wd/Spindle 2wd) and some good shocks and bump stops. I had nothing but problems with long travel sus. for these trucks, WAY TOO HEAVY. The frame was definitely not designed for a 7k lb truck to handle woops with no consequences. It can be done but be weary of the frame rails and the diesels are not easy to get tubes over the motor for proper trussing.
  18. NolanYAZ
    NolanYAZ Member
    Apr 10, 2010
    Yuma, AZ
    Just picked up my JD Fab kit for my 05 4x4 1500 on Monday, the axels are custom 300m
  19. NolanYAZ
    NolanYAZ Member
    Apr 10, 2010
    Yuma, AZ
    whoa this thread is OLD
  20. Carlos91
    Carlos91 New Member
    Jul 9, 2016
    Lake Elsinore ca
    Looking for someone to long travel my 04 Chevy Silverado 2500HD 2wd 6.0 (gas) if anyone knows of someone please let me know
Verification:
Draft saved Draft deleted
Share This Page
