    Dismiss Notice
Drive shaft max length??
Discussion in 'Shop - Driveline' started by RyanWiW, Mar 30, 2009.
  1. RyanWiW
    RyanWiW Well-Known Member
    Nov 27, 2007
    torrance, ca
    Does anyone know what the maximum length of a one piece drive shaft can be. I just put a 302 with a turbo400 in a 96 tacoma and would like to run a one piece slip shaft. The shaft would have to be about 62" long. if this is too long, i have to run a two piece which will increase plunge and operating angles. Any ideas would be helpfull!
  2. Samco Fab
    Samco Fab Well-Known Member
    Dec 5, 2005
    Reno NV
    I have seen a couple of V8 Rangers run driveshafts that are at least that long ( if not a foot longer) with no problems. You probably want to run a bit larger than normal diameter to get the strength and rigidity, at least a 3" diameter.
  3. Jess@HighAngle
    Jess@HighAngle Well-Known Member
    Jan 25, 2007
    Paradise , California
    A 3 1/2 tube may be best - Jess
Verification:
Draft saved Draft deleted
Share This Page
