    Dismiss Notice
ELITE early Bronco build
Discussion in 'Shop - Show & Tell' started by Race Whore, Apr 25, 2011.
  1. Race Whore
    Race Whore Well-Known Member
    Oct 8, 2009
    Race mile 999 Running clean
    I bought a 1970 Bronco over a year ago, and this project has escalated out of control. I am building it to be similar to the early race Bronco's (i.e. Crazy Colt, Big Oly), except with modern day technology. Custom built by Elite Auto Service
    For starters; TLR shackles and brackets / 5.0 Roller Cobra engine/ Powder One powder coating/ Mastercraft safety prod./ Custom Bronco parts by Wild Horses/ Competitive Metals/M.I.T. drivetrain/ Valley Transmission Custom Trans.
    Much more to come....
  2. Race Whore
    Oct 8, 2009
  3. Race Whore
    Oct 8, 2009
    First off, was the body work. We fixed all of the dents and welded every bolt hole from 40 yrs. of accessories. Shaved the door handles. Cut the door frames off and welded the window slot shut (there will be no side windows). Customized the windshield frame to allow for a smaller window. These things resemble the retro race look. Then pulled the body off, for more work.
    We sent the chassis to TLR Racing for Tim’s custom radius arm brackets with uniballs. Relocated the spring hangers, custom shackles, trac-rods, and reinforced transmission brackets. Reinforced the frame for the HOWE p/s steering box.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  4. ErikShallbetter
    ErikShallbetter Well-Known Member
    Oct 31, 2005
    Minnesota
    Cool project for sure! I love old Broncos. The plate work and the welding look really good. Keep us posted!
  5. Dezertpilot
    Dezertpilot Well-Known Member
    Jul 26, 2005
    Gods Country North Idaho
    Super cool, def look forward to this build. Please keep us updated! Never seen those uniball radius arms before, how do they compare to heims?
  6. PDANK Racing
    PDANK Racing Well-Known Member
    Nov 27, 2010
    Green Bay,WI
    Great job so far, definitely going to be a fun rig. Always been a bronco fan, especially the early ones.(except for the II, still trying to forget that POS)
    Keep the pics coming.
  7. Race Whore
    Oct 8, 2009
    A uniball or heim rod end are basically the same in function, just mount differently. These work well in allowing the front end to drop out, but slide right onto a stock radius arm.
  8. ntsqd
    ntsqd Well-Known Member
    Sep 17, 2001
    Here
    I worry that the thrust load capability of an SRE used in that orientation may not be up to the job. The direction that the loads are applied is not the same as with when those are used in a SLA front suspension as the upper or lower ball joints. In this orientation every bump the front tires hit will be driving the balls backwards out of the races, and the races backwards out of the pockets. Far less than an ideal loading. I guess we'll see how well they work that way, I've over-estimated the loads before.
  9. Race Whore
    Oct 8, 2009
    We and many others have been using them for 15 years of racing and prerunning. Closely check a I beam Stock Full and you may see them hidden in there. They can take the load for years. I know what you saying, but they are very durable and cycle well.
  10. Scott_F
    Scott_F Well-Known Member
    Dec 28, 2003
    Tucson, was Anaheim
    Tom, haven't seen you post in years. I agree with you. At the very least the cup should have been reversed so the loads are not on the snap rings. But if it works it works.
  11. Race Whore
    Oct 8, 2009
    Simple, you weld a boss on the back side to support the uni-ball. The boss supports the load. The snap ring is on the front.
  12. Racerinside
    Racerinside Well-Known Member
    Aug 20, 2007
    Lemon Grove, CA
    Uniball will be fine for the radius arm brackets, remember the stock bracket is an 1/8th in. thick stamped metal with over sized hole and rubber bushings. If a class 7s truck can make them last a prerunner will have no problem with them.
  13. Race Whore
    Oct 8, 2009
    Next the frame was powder coated by Powder One.
    Custom Dana 44 by M.I.T. Drivetrain with locker, 5/8 wheel studs and f-150 knuckles
    5.0 Cobra motor built by Raymond @ master Cylinder Head Services of El Cajon. Includes roller Schneider cam, forged pistons, ARP bolts, and head work for better power. Polished Edlebrock intake
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  14. Scott_F
    Dec 28, 2003
    Tucson, was Anaheim
    Sorry, I thought it looked like it was in the rear. The pic is a little fuzzy.
  15. BRINGTHERUCKUS
    BRINGTHERUCKUS Nimrod de PMC
    Apr 28, 2005
    Parker, Arizona
    WHAT!? those cheating bastards!
  16. yellowranger1
    yellowranger1 Well-Known Member
    Sep 28, 2006
    Sylmar, Ca.
    I don't post on here much, but as an EB owner myself (stock/uncut '73) this is currently one of my favorite builds. Have you posted this on any of the EB forums? The work looks top notch, I'll be tearing mine down in the next month or two for a frame off, so I'll be referencing your thread for tips and inspiration. Keep up the good work and keep us posted! Good luck with the rest of the build!
    - Eddie
  17. ntsqd
    Sep 17, 2001
    Here
    Keep in mind that the stock bracket wasn't expected to survive the kinds of loadings that vehicles on this forum see, and that with the rubber in there that it had some degree of shock protection. Kind of the difference between hitting it with a 2 lbs sledge vs. hitting it with a rubber mallet.
    Speaking of the rubber strut bushes, the only Stock Full that I've spent any time around very successfully used the stock rubber bushings. It never DNF'd because of the stock rubber bushes, but it did DNF due to those bushings every time that they tried to use urethane.
    As I previously posted, I've over estimated the loadings in the past, but this orientation is the least strong way to use an SB, even if the pocket does back up the race.
    But enough about that, back to what promises to be an interesting build of an Early Bronco.
  18. Ocotillo Explorer
    Ocotillo Explorer Well-Known Member
    Oct 15, 2009
    Alpine
    Look again. That is not the stock bracket for the radius arms. Those brackets are very strong. )The stock ones are smaller than a baseball). By the way its an early Bronco, not a trophy truck. This Bronco will be awesome.
  19. DirtWorshiper
    DirtWorshiper Well-Known Member
    Oct 5, 2009
    Roseburg, OR
    Great looking build. I wish my EB looked half as good.
  20. LIMITLESS
    LIMITLESS Well-Known Member
    Feb 5, 2009
    Dubai, United Arab Emirate$ & Alpine, CA
    John, Cool build, im looking forward to finished product!!!
Verification:
Draft saved Draft deleted
Share This Page
