    Dismiss Notice
Ford 6.0 Diesel Mechanic
Discussion in 'Shop - Engine' started by Waldo, Mar 1, 2012.
  1. Waldo
    Waldo Safehouse
    May 15, 2001
    Ladera Ranch, CA
    Need a mechanic for some work on the PorkPits' diesel. She's got some injectors that need some TLC (no longer under warranty). I shy away from dealers based on prior experience BUT if anyone on here is a Ford/Diesel mechanic, I'd like to keep it in the family! I know of a couple shops out of my area (san jacinto/hemet) so I'm looking for anyone semi-local.
    Thanks.
    ~Waldo
  2. buckwild
    buckwild Well-Known Member
    May 22, 2007
    San Diego ,CA
  3. manicmechanic
    manicmechanic Well-Known Member
    Dec 11, 2005
    Washington
    Buyer beware. I am more chapped at ford for there pull the cab to work on it design than at navistar for there junk EGR and engine oil coolers. We are now finding that the 6.0 ironed out was the good engine just as we said about the 7.3L. We did hire another mechanic to survive the 6.0 era and I dont think the 6.4 is going to let him down so its all good. Jurys out on the 6.7.
    I am pushing to go gas v/10s for medium duty trucks in our fleet until deisel emission are ironed out.
  4. JEFFRPM
    JEFFRPM Non Sugar Coated
    Jan 7, 2008
    Under the Tetons
    So does this mean I will be gettting the money i have spent on my two 6.0 engines, injectors,turbos,egr coolers,head gaskets? the last one that went POOF i drove from the service dept with the service ID number still hanging from the rear view mirror and the ID tag on the key ring straight to the used car dept and asked "what will you give for this thing" i sold it for a $22000.00 loss the way i see it i saved 22k cause those engines are at that time $18000.00 installed complete with dash rattles mushy brakes crooked steering wheel and the carpet wadded up from the cab being removed 4 times yea those trucks were / are the biggest piece of $h it t i have EVER seen.
  5. DezertRaders
    DezertRaders Well-Known Member
    Jun 9, 2006
    San Clemente, CA
    If you want some help and a little TLC call me. Yes I run a dealer down is SJC. If you are not in a huge hurry, I can save you a bunch 949-289-0099 Rich
  6. Waldo
    Waldo Safehouse
    May 15, 2001
    Ladera Ranch, CA
    Thanks...I'll hang onto your number!
  7. TMorford
    TMorford Well-Known Member
    Mar 16, 2006
    San Marcos CA
    The SM Ford Fleet Center's service manager is a former 1450 racer, give them a call and ask for Nicolette.
  8. KevinT4R
    KevinT4R Well-Known Member
    Dec 6, 2010
    Whittier, CA
    Loren and the crew at Diesel Tech are worth the drive to San Jacinto...but you probably already know that.
    Off-Road Magazine has a troubled '03 6.0-equipped Super Duty (called the STD for Super Turd Diesel) that would have died (and stayed dead) long ago if not for Diesel Tech's expertise.
  9. Stone_ld
    Stone_ld New Member
    Apr 1, 2012
    ca
    Hello, Every vehicle needs servicing at some particular time or to be repaired and diesel mechanic plays a important role for it's maintainability factor. If one is looking for some particular vehicle like for Ford, there are many diesel mechanic and they are well in there duties. diesel mechanic
  10. dirtdriver85
    dirtdriver85 Well-Known Member
    Feb 7, 2005
    Hemet CA
    Diesel Tech
Verification:
Draft saved Draft deleted
Share This Page
