    Dismiss Notice
Ford 9 inch rear end bolt pattern???
Discussion in 'Shop - Driveline' started by atomicjoe23, Apr 20, 2009.
  1. atomicjoe23
    atomicjoe23 Well-Known Member
    Feb 2, 2008
    Silverdale, WA
    Does anyone know what the bolt pattern of a Ford 9 Inch rearend is???
    I'd like to make my own rear end in welding class and I think the one super critical area is gonna be getting the bolt pattern correct. . .I need the bolt pattern so that I can make a pattern in AutoCAD and get the stud plate laser cut so that I can fab a housing, etc.
    Thanks!
  2. dwjet2
    dwjet2 Member
    Mar 31, 2009
    Phx,Az
    I dont know what the pattern is but if you search this site its been posted in solids works before. if you cant find it pm me and i can email you a dxf file when i get home.
    Tom
  3. JEFFRPM
    JEFFRPM Non Sugar Coated
    Jan 7, 2008
    Under the Tetons
    Buy a gasket:cool:
  4. atomicjoe23
    Feb 2, 2008
    Silverdale, WA
  5. dwjet2
    dwjet2 Member
    Mar 31, 2009
    Phx,Az
    I email it to you this morning atomicjoe. I did not creat this file so i can not verify the accuracy of the hole pattern, but its something to start with.
    Tom
  6. atomicjoe23
    Feb 2, 2008
    Silverdale, WA
    Thanks DWJet. . .greatly appreciated. . .I love how everyone is willing to share this type of information and CAD/SolidWorks files on this forum!!!
  7. rharriman
    rharriman Well-Known Member
    Aug 11, 2008
    If you have the ability to plot a full scale of the pattern you use, you may want to compare it to the gasket or the rear end gear set you plan to use just to be safe. I have also seen several variations of the notch for assembling the gear set so check that out too. I will post some dimensional drawings here for ya later. Also check trails less traved, they have a dxf there too.
    Ford 9 Third Member - Trails Less Traveled
  8. atomicjoe23
    Feb 2, 2008
    Silverdale, WA
    Thanks rharriman. . .I can plot full size and will definitely verify it once I get a chance.
    Thanks again to everyone!!!
  9. CRAIG_HALL
    CRAIG_HALL Well-Known Member
    Oct 28, 2002
    San Diego
    here's the thread that has a post with a zip file for the cad drawing..
    CLICKY
Verification:
Draft saved Draft deleted
Share This Page
