    Dismiss Notice
Fuego question
Discussion in 'Shop - Electrical' started by usmcgunrock, Mar 4, 2012.
  1. usmcgunrock
    usmcgunrock Well-Known Member
    May 30, 2006
    Lakeside, CA
    Does anybody have experience with the wide cornering beam pattern? I was looking to put 5 on the front of my Dodge 3500 for chase duties and was thinking 3 driving and out side two wide cornering. But I don't know anybody who have used or seen that beam pattern. So the question is would I be better off with just getting 5 driving pattern lights? I don't think I will ever get my 3500 dually moving fast enough off road to need any spot ones. Also was thinking maybe useing the wide cornering beam as work lights on a chase rack. It is that or D2's. Input appreciated, thanks.
  2. Dreamcatcher
    Dreamcatcher Well-Known Member
    Sep 17, 2008
    Eastlake, CA
    I ran 2 wide cornering HIDs in my Dodge bumper. But when I was chasing in Baja I also ran 5 La Paz as well. 4 driving 1 spot.
  3. D. Freeman
    D. Freeman Well-Known Member
    Feb 23, 2009
    The wide cornering beam is 42 degrees wide. It will work nicely when used in conjunction with the driving pattern. Your proposed setup would work very well!
  4. Finch
    Finch Active Member
    Nov 24, 2009
    Peoria, Az
    im currently running 4 La paz drivers, with 2 fuego wides in the fog light locationworks extremely well
  5. Dreamcatcher
    Sep 17, 2008
    Eastlake, CA
    I also have Fuego wides on each side and the rear on my rack. Honestly, it is overkill with almost too much light. I would probably recommend something a little less powerful.
  6. Finch
    Finch Active Member
    Nov 24, 2009
    Peoria, Az
    the new squadran lights would be perfect
Verification:
Draft saved Draft deleted
Share This Page
