    Dismiss Notice
KIBBETECH 2004 silverado build
Discussion in 'Shop - Show & Tell' started by kibbetech, Jul 25, 2009.
  1. kibbetech
    kibbetech Well-Known Member
    May 18, 2009
    thousand oaks ca
    its my kit, me and my partner doin all the work and our OWN cad
    (+1) 1 person likes this.
  2. kibbetech
    May 18, 2009
    thousand oaks ca
    few more from today
  3. Dezertpilot
    Dezertpilot Well-Known Member
    Jul 26, 2005
    Gods Country North Idaho
    Looks good keep us updated, what are the overall plans?
  4. TheHoov
    TheHoov Well-Known Member
    May 7, 2009
    San Juan Capistrano
    Lookin' good.. I cant wait to see it all done up!
    HooV
  5. Mcarlson1
    Mcarlson1 Well-Known Member
    Apr 10, 2006
    Kerman,CA
    What are the specs on the kit? What all are you doing to the truck? Looks good so far.
    Thanks,
    Mike
  6. Mark Newhan
    Mark Newhan Well-Known Member
    Nov 22, 2005
    Lakeside, ca.
    Clean work!
  7. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    All that work and you couldn't do anything about the positive castor at full droop?
  8. tool46n2
    tool46n2 Well-Known Member
    Nov 14, 2007
    Whittier, CA
    Very clean work. Nice tight welds too. Keep up the good job, and bring on the pics.:)
  9. kibbetech
    May 18, 2009
    thousand oaks ca
    Acctually there is no positive caster in it. It just looks like it in that picture. It lays back 7 degrees through the entire cycle.
  10. kibbetech
    May 18, 2009
    thousand oaks ca
    The kit is pulling 26" of travel with a 12" shock. Has 1 degree of camber change at droop and 8 a bump. The truck will be getting a roll cage, tube/plate rear half, and 4 link with our trailing arm and rearend housing.
  11. BajaFand
    BajaFand Well-Known Member
    Oct 17, 2005
    Norco, CA
    Was that a typo? Did you mean 16"?
  12. Dezertpilot
    Jul 26, 2005
    Eric I was sorta wondering the same thing...
  13. kibbetech
    May 18, 2009
    thousand oaks ca
    no i meant 26" running a taller spindle with the upper tabs higher and more torwards the center of the truck allowed for 26" with minimal camber change.
  14. Steven_Tolbert
    Steven_Tolbert Well-Known Member
    Oct 7, 2007
    Pinon Hills
    Bad @$$ !!!!
  15. KCMotorsports
    KCMotorsports Well-Known Member
    Jun 14, 2009
    CA
    How is your bumpsteer and tire scrub?
  16. kibbetech
    May 18, 2009
    thousand oaks ca
    less than 1/8in of bumpsteer. theres only so much you do with scrub with out going center mount, but its not alot
  17. Tyler7
    Tyler7 Well-Known Member
    Sep 5, 2006
    La Crescenta, CA
    that thing looks nutty!
  18. Mcarlson1
    Apr 10, 2006
    Kerman,CA
    Holy Sh@* 26"!! How wide is it going to be?? Bumps running on the lower arms or off of the shock mount onto the spindle?
    Thanks,
    Mike
  19. kibbetech
    May 18, 2009
    thousand oaks ca
    around 92" and the bump will hit the spindle. the tube arm is temporary for moch up, im getting a billet one machined
  20. kibbetech
    May 18, 2009
    thousand oaks ca
    this is what will be going on the rear...
Verification:
Draft saved Draft deleted
Share This Page
