    Dismiss Notice
SCORE/BITD Class 1000 (Class 10?) Engine Rules?
Discussion in 'Desert Racing' started by K-fab, Mar 22, 2006.
  1. K-fab
    K-fab Well-Known Member
    Feb 4, 2006
    Scottsdale, AZ
    I'm in the process of building a new race car - newer version of the ride I've been beating about the desert the past five years (see link in signature below).
    This vehicle is not really like regular racers - it's small, light and uses a belt drive CVT transmission setup. Think snowmobiles or Honda Pilots/Odysseys (not the minivans)
    I have some questions concerning my engine setup and where it would land in the SCORE and BITD rules.
    Engine:
    Yamaha RX1 Snowmobile engine
    Four cylinder, four stroke, 1000 cc - FIVE valves per cylinder - three intake, two exhaust.
    The engine's based on the Yamaha R1 crotch rocket bike.
    Fuel injection system - off the R1 bike. Four throttle bodies.
    Properly tuned, it makes about 160 hp and about 120 ft-lbs of torque. (not bad for a 1200 lb car)
    From what I've read in the SCORE and BITD rules, it sounds like, even though I'm down 800 ccs on displacement (two seater), the five valve setup shelves this engine.
    Does SCORE or BITD ever take a "special look" a particular setup and allow it? Does anyone think that this powerplant may be allowed to race in Class 1000? (Score calls it Class 10, right? - sorry, I don't have my SCORE handbook handy - I left it in Phoenix, I'm in Cincinnati...)
    I really want to step up from Whiplash and come join you guys in SCORE and BITD, but I want to remain in "Class 10". By the rules, I could run Class 1, but the idea of having to leave the line with the bigger cars scares me for the time being. (and I don't think I'd have a snowball's chance...)
    Thanks in advance.
  2. partybarge_pilot
    Feb 19, 2002
    Easton, KS
    The main problem you will have with SCORE is the rules state "automotive based engines". Another sticky spot could be the FI as the RX1's are carburated. If you use FI it has to be a factory set-up. For carbs you are limted to a single 38MM 2-barrel?
  3. Ramsey_ElWardani
    Ramsey_ElWardani Ironman
    Apr 1, 2001
    No, it doesn't fit the rule.
  4. K-fab
    Feb 4, 2006
    Scottsdale, AZ
    The 2006 RX1 engines (actually, Yamaha's renamed the 2006 four stroke sled line, but I can't recall the name) come with FI stock.... Who's to say I don't have a 2006 engine??? :rolleyes: :p
    Automotive based engine....
    Yamaha made the engines for the old Ford Taurus SHO - so, yea, it's an automotive thing!!! :eek:
    You've confirmed my worries... Drats.
  5. EOR1488
    EOR1488 Well-Known Member
    Aug 31, 2005
    Albuquerque, New Mexico
    How about the Hiabusa motor thats what I was going to run in a 10 car. its 1.3l you can take it to 1650 or higher in a 2 seater and it will make anywhere from 200-250hp 160-180lbs tq. Thats of course after you port and polish the heads and do some tuning. Thats what I would go with. Heres a link to a builder http://www.carpenterracing.com/porting.htm go under his sport bike packages he has some great stuff!!!
  6. EOR1488
    Aug 31, 2005
    Even if you had a light like you said 1,200lb buggy with 250hp even if you couldnt race class ten I bet you could do pretty good at the Terribles cup in Class 1. You would have a better power to weight ratio(4.8) then a porter with 700hp.(5)
  7. K-fab
    Feb 4, 2006
    Scottsdale, AZ
    I've been in Busa powered cars (Jay Largo's Desert Dog Off Road Coyotes) that are the same size/weight as mine.
    I, to put it mildly, HATE that engine. - and the fact that I have to shift it made it even less fun.
    The first three gears are totally useless - spin, spin, spin (yes, I understand throttle control) and you still have to have a chain driving the transmission I use - the chain burns up quickly. You can't get the output gearing from the engine to the transmission overdriven enough. I think the car was capable of close to 120 mph, but still - not the powerplant for me.
    I appreciate the idea, though. :)
  8. EOR1488
    Aug 31, 2005
    Well I have seen trannys for them. Butting bigger tires you get less slip. Thats to bad though I had a gsxr-1000 and loved it and I rode a busa great bike but it wasnt in a buggy.
  9. Hemp
    Hemp Well-Known Member
    Nov 16, 2004
    Fullerton, Ca
    an automobile doesnt neccessary have to be a car or truck
    an automobile is a self-propelled vehicle capable of carrying a passenger
  10. prerunner1499
    prerunner1499 Well-Known Member
    May 6, 2003
    Springfield OR
    BS,, an automobile is a 3 or 4 wheel vehicle capable of carrying at least 1 passenger, powered by an internal combustion or electric motor.
    If its got 2 wheels,, then its a motorcycle,,,,,, period!
  11. movindirt
    movindirt Wham Spore
    Apr 15, 2005
    Pacific Grove
    According to this a motorcycle is in the group Automobile: http://en.wikipedia.org/wiki/Automobile
    There you go K-Fab.. Really like the reading about your cars. Can't wait to see what the new motor can do.
  12. K-fab
    Feb 4, 2006
    Scottsdale, AZ
    Hey, you two quit fighting! :eek:
    The engine is out of a SNOWMOBILE! - so there.... Puts that arguement to rest! :rolleyes:
  13. pedal2metal
    pedal2metal Well-Known Member
    Mar 1, 2006
    Julian, CA
    Your other issue might be what is currently your best attribute- your car being lightweight. If I remember right, class 10s must weight at least 1550 pounds, so putting a bigger motor in might not hurt you as it could bring you up to legal weight while giving you a legal motor with competitive power. You'd still be at an advantage over most every other class 10 because as far as I know, the Hunter car that Rob MacCachren drove at Laughlin this year is the only 10 car that sits right on the weight limit. If your car had the same power as the rest of the class 10s but weighed some 500+ pounds less (as most of the current class 10s weigh 2000 pounds or more by my estimation), then you'd have a great chance of success, as Hunter's car is still full of teething problems and rarely races. Good luck!
  14. HDRA1
    HDRA1 The Godfather
    Sep 26, 2005
    las vegas nv
    two words Mini-Mag =no longer snowmobile motors been there done that
  15. K-fab
    Feb 4, 2006
    Scottsdale, AZ
    Well, after a bunch of inquiries, research and such, it looks like the five valved setup I wanted to run won't be viable as a SCORE or BITD legal powerplant. Bummer...
    It looks like I might be running a Honda 1600 Vtec instead. Vibrating beast... I'm still looking for alternatives, though. The one I have access to is supposed to be a ripping little powerplant. I need to make some phone calls and get specs.
    Bottom half of the chassis is in process - jigged up this week. Wish I had pix.
  16. Chris_Wilson
    Chris_Wilson Well-Known Member
    Apr 4, 2001
    San Diego
    Would it be cheaper to put a $6k LS1 in it and run class 1? Just wondering.
  17. dhardesty
    dhardesty Well-Known Member
    Oct 17, 2002
    Poway California
    Join the Air Cooled (VW)Revolution!!!! From what I've read, sounds like you have a lite car. Go with torque!! There is no weight limit in class 10.
    Good Luck!
  18. Fourstroker
    Fourstroker Well-Known Member
    Jan 14, 2004
    Garden Grove, CA
    I'm with you. Air-cooled til I die...Or have a $hitload of money sitting around
  19. elmariachi
    elmariachi Well-Known Member
    May 8, 2006
    West Covina, CA
    I think there's something to be said for small buggies such as these. I remember back in the mid 80's a company called Pro-ATV made a car that ran Honda Odyssey running gear (motor, CVT drive, etc.) on custom frames (I haven't been able to find anything on this company though - I know they were located in North Hollywood, CA. Anyone have any leads as to what became of this company?). I know they did run in SCORE sanctioned races (it was Class 43 I believe) and they ran with the three wheelers (this was before quads - see the attached picture).
    I think a new class of cars limited in weight (less than 1500lbs. race ready), engine displacement (probably less than 1000cc), and wheel base (no more than 8 feet) would be a great thing for the sport. It would allow those on a tight/limited budget to participate and compete. Also, this could be a training ground for younger drivers before they move up to bigger, more powerful cars/trucks. I think this is also why you have the emergence of the Rhino/Ranger (UTV) class. These offer an inexpensive way to go desert racing - just too slow. I know these UTVs have completed in races but not finished under the posted time limits.
    What do y'all think?
  20. movindirt
    Apr 15, 2005
    Pacific Grove
    Cool little car but it does say Susuki on the side so it may not be a Honda motor.
Verification:
Draft saved Draft deleted
Share This Page
